Question about Husqvarna Garden
Husquavarna GT2254 runs fine till I try to engage the blades,
Then engine dies and blades do not engage. How do I test the PTO switch
  • 246 Answers
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
Had the same problem with my husqvarna i replaced the pto switch with a simple toggle works fine.
Posted on Aug 23, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
Why would blades just stop when mowing with ex mark lazer Z (model lz25kc604) I had beeing mowing for about 6 hours. Then it just stopped
It sound like the PTO clutch has died.
Test your PTO clutch. It should have a resistance of 1.7 to 2.5 ohms.
Jul 27, 2014 | Garden
Motor stalls when PTO engaged
its ether the regulator or the stator in the engineas for as the pto killing the engine it might only need a govenor adjustment to take care of that problem
Jun 22, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Husqvarna 17530 stalls when engaging the blade. Seems to run fine else wise/
Does engaging the pedal for the PTO lug the engine down, or does it just die like turning off the key?
If it lugs the engine down, then you need to make sure you can spin the spindle and idler pulleys by pulling the belt by hand. You should be able to slip it around the engine pulley enough with the blade pedal disengaged. Pull the belt up tight so the slack is around the engine pulley and try to spin the blade spindle and idler pulleys.
If it dies like turning off the key, then its likely a safety switch and may require a meter to test which.
The seat switch is has a shunt in the circuit that must be satisfied in order for the rest of the circuit to be happy. Make sure the connections are good, the pins inside the amp connectors will sometimes spread, push out of the lock etc. and if connection is lost will not work. Otherwise a new seat switch will be needed. You might check the PTO switch for continuity, without a diagram or schematic I am not sure how your circuit is wired. you have to have the parking brake engaged to get off the mower while the engine is running and the PTO is Dis-engaged?
I don't know if your "go" pedal eliminated this switch or not. But if with the parking brake engaged and the PTO disengaged, you lift off the seat and it dies, then its the seat switch.
Hope this helped Tim
May 21, 2011 | Husqvarna 24HP 54" Yard Tractor ()
The engine starts and runs fine. but when I try to engage the blades or release the clutch the engine tries to go dead like a saftey switch is bad
Its called a PTO switch.
Visit www.searspartsdirect.com and enter your full model number for a breakdown of parts and ordering options.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I engage the front PTO the engine dies.
There is somthing in the PTO that is binding up. I am assuming the PTO is for the mower blades. The belt(s) could be binding up, not on the pulleys, etc. The blades should turn by hand easily.
Oct 13, 2009 | Garden
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Garden Logo
857 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
