Question about Casio Office Equipment & Supplies
My casio HR-16A BK adding machine is not working
My adding machine is not working i have the roll inserted correctly i know the batteries work but the adding machine wont turn on.
4 Suggested Answers
  • 566 Answers
SOURCE: Need help replacing the paper roll on a Casio BIG
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Posted on Aug 22, 2009
jackcity
  • 33 Answers
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Posted on Sep 13, 2009
  • 365 Answers
SOURCE: Cannot change +5% TO -10%
To chance tax rate follow this: Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key and then press the TAX+ key. It should save the new tax rate.
I'm not sure if you can set negative tax values. I believe it is meant for positive tax percentages only.
Chris
Posted on Aug 15, 2011
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Can I take the cover off my casio HR-15OTE desk calculator?
There's no need to take the cover off.
Use a fresh piece of 'blue tack' (white doesn't work as well), rolled into a ball, to clean your keys.
Feb 12, 2015 | Casio HR-150TER Calculator
Replace ink roll for Casio 100TM
Should just be a matter of lifting up the lid, removing the old roller and replacing it with a new one. That's how mine works.
Oct 10, 2014 | Casio HR-100TM Two-Color Portable Printing...
What kind of paper does the Casio DR-220 hd calculator use?
The Caiso DR220HD takes a Universal 2-1/4" x 150' Calculator Paper Rolls
Calculator and adding machine paper rolls.
2-1/4" wide. 150' in length. 1-ply.
Your local office supply store shoudl carry this. or order online here:
Free Shipping On Casio DR 220 HD Paper Roll DR220HD
http://www.worldclassink.com/Casio-DR-220-HD-Paper-Roll-printer21507-ift198.html
Aug 12, 2014 | Casio Office Equipment & Supplies
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
What ribbon cartridge do I use for HR-8TM Casio Calculator
  • Nu-Kote NR42 Compatible Ink Roller
  • Single-Ply Adding Machine/Calculator Roll, 16lb, 2-1/4"x150
Mar 04, 2011 | Casio HR8TM Calculator
How do I change the paper tape roll on casio HR-100TM?
Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
Mar 02, 2011 | Casio HR-100TMPlus Calculator
How to add ink to a casio adding machine
Replace the ink roll. they snap in fron the top. IR 40 is the nomber.
DickyO
Feb 22, 2010 | Casio HR-100TMPlus Calculator
BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Mar 17, 2008 | Casio HR-8TEPlus Calculator
480 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
