I can not get my system boot up it says Windows 32 /system file missing.......... what to do
  • 67 Answers
Your operating system seems to be Corrupt. you need put windows xp Cd and repair the windows
Posted on Apr 21, 2009
Won't boot up
dll system 32 files missing install these files or format and reinstall windows
Aug 17, 2012 | Toshiba Satellite A105-S4074 Notebook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Notebook says that windows could not start because the following file is missing or corrupt &lt;windows root&gt;/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
The laptop shows windows system 32 configuration file corrupt error how to run laptop?
Hi
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Jan 13, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
In system 32 boot vbs is missing .how to
Do a repair install from the windows xp disc.
Apr 24, 2010 | Microsoft Windows XP Professional
A FILE WINDOWS SYSTEM ROOT 32 IS MISSING OR CORRUPT
Try starting in 'SAFE MODE'.
Click START
Click RUN
Type CMD and press ENTER.
Type 'CHKDSK C: /F' and press ENTER.
If you are prompted to shutdown & restart to run the "check disk", do so.
During the restart, "check disk" will find/repair any file-system problems, and then restart in "normal" mode.
Sep 18, 2009 | Compaq Presario 5000 PC Desktop
32.dll missing problem
32.dll is not a windows file,Is any file name written before the 32?
If not it is probably part of a virus that was not completely removed.
If you can log in to windows,do a search for 32.dll and delete(DO NOT DELETE IF ANYTHING IS WRITTEN BEFORE 32)
If you can't log in,You may need to do a fresh install.
Please rate this solution.
Jan 17, 2009 | IBM NetVista PC Desktop
Deleted dll
BOOT FROM YOUR WINDOWS DISC AND CHOSE OPTION RECOVERY CONSOLE AND USE THE GUIDED HELP...BUT FIRST DOWNLOAD THE MISSING FILE AND COPY IT TO WINDOWS 32 SYSTEM FILE FOLDER.RICHARDM69
Dec 01, 2008 | Dell Dimension 8100 PC Desktop
Windows 32 file is missing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0mm 5.4pt 0mm 5.4pt; mso-para-margin:0mm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows 32 file is a system file this one along with others if faulty or corrupted will stop windows working
The easiest way in the long term is to.
Boot from Windows CD and after all files are loaded. Windows will ask you what you want to do. Install, Repair etc. Choose repair and follow instruction from there Windows will remove some files and reinstall in repair mode. You will not lose any files, during this process.
The reason I choose this method is because you can spend some hours trying to fix not starting problems and not succeed while a reboot in repair mode takes ¾ of an hour plus time to load drivers
Oct 17, 2008 | Intel D845GVSR Motherboard
Windows dont start
It means that some files needed for windows to restart are missing,probably a system file or boot files. Some windows xp users usually re-install and repair their windows xp system using their original windows xp install disk and selecting the "repair" ooption. But another practical solution is to note down the missing file, then,on another PC using the same system,search for that file and copy, though you will have to note the folder location of that missing file from another PC. Boot your PC (the one that doesn't boot) with a system diskand on the command prompt (DOS prompt) copy the missing file from yourcopy disk to the same location where the missing file should be situated.
If the practical suggestion wouldn't work, then you have to re-install your windows on top of the current installation using your windows cd to repair yourwindows sytem, if this still doesn't then you have to install a new windows systemlocated in a different location in your disk, this way you still go to your saved files and backup your files.
Apr 18, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
