Question about Philips JackRabbit II (JR24CDRW) CD-RW Burner
Tapco link.usb Just purchased the Tapcolink.usb and am having a problem getting sound via my computer which is plugged into one of my USB outlets. I have used the instrument input on the Tapcolink.usb from my Technics Synthesizer, coming from it's plug outlet that I usually plug into my amp. I have pre recorded floppy disks on the Synthesizer and am trying to record them on my CDRW drive on my desktop. Is there any adjustment that I must make on my computer to produce the sound. I am able to play CD and DVD's on my computer without any problems. THanks for your help.
SOURCE:
  • 432 Answers
SOURCE: sound not recorded
You need an 1/8" male jack plug (both ends) cable. One end plugs to audio out on TV card, the other end plugs to audio in on the sound card. Or is it the other way around. Anyway, thats what you need. I think Radio Shack sells them maybe BestBuy or Circuit City.
Posted on Jul 02, 2007
  • 298 Answers
SOURCE: sdvd8441
Use Nero if any of those other programs show up
on the dropdown menu of burners dvdrom player
etc you will have to unistall completly the drivers
every mention of the other ones in the registry
It always a good idea to clean the registry of
entrants to uinstalled programs those old
keys and strings can cause problems
Posted on Dec 07, 2007
  • 476 Answers
SOURCE: Philips Hard Disk/DVD Recorder Model DVDR3370H/97
There was a compatibility issue with this model. Philips released a software update for this model.
Follow this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20080216151231_81.77.115.133&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3380/05&mid=Link_Software&hlt=Link_Software
Read and follow the instructions CAREFULLY.
Posted on Feb 16, 2008
mitch_3020
  • 70 Answers
SOURCE: Driver problem with DVD/CDRW device driver
Hi sandystell,
Well normally in Windows XP the DVD/CDRW drive won't need anymore drivers, since Windows automatically installs one for it. I assume the problem you're having is that the drive is not able to read CDs/DVDs or burn a disc, correct?
If that is the case you can actually follow this microsoft KB article: http://support.microsoft.com/default.aspx?scid=kb%3Ben-us%3B314060
This will give you indepth help on what to do. I would recommend that you do the removal of the upper filters and lower filters in the registry.
You can test if the optical drive works in Safe Mode, by pressing F8 on startup and choosing Safe Mode, then logging into yourr account. See if the disc is read in Safe Mode, if it does, then you have a program that is conflicting with the drive. I would recommend that you run MSCONFIG, goto Startup tab and disable most if not all of the startup items, then click on APPLY then OK.
The next thing is running the diagnostics for the computer to see if there any reported hardware problems. Now if all tests passed, the next step is reseating the optical drive (if possible) check the computer manual on how to do procedure, otherwise you may have to call up Dell Technical Support.
Now you may have to replace the drive itself since it could be defective now.
Hope this helps!
Peace! :)
Posted on Oct 20, 2008
epik559
  • 44 Answers
SOURCE: Is a Magnavox MWR10D6 DVD Recorder codec or driver needed to play DVD disks on computer?
There are work arounds... but the reason is when its burnt and finialized its written in .vob format which is dvd mpeg2 format. majority of windows media player codecs wont pick it up. divx does. its just the format its burnt in and you cant change obviously. you can just try like nero showtime which always works or ending up ripping the disc on the computier but that might defeat your purpost of burning them in the first place. Its not the dvd recorder i may add, its just the format. by the way its a magnavox unit made by funai... www.funai-corp.com/support and trust me your not going to get much out of their. your better off going into forums finding more high depth problems if you really want this to work for firends and families and such.
Posted on Oct 31, 2008
Cant get my tapco link midi 4x4 to be found by my PC w/vista.
TapcoLINK help:
I found this on www.recording.org
http://recording.org/home-recording-forum/39765-tapco-link-usb-and-tracktion-2-a.html
Ok first thing. Unplug any USB devices not pertinent to recording when you want to record. Second, left click Start->right click Computer and select properties. Left click on Device Manager (left column). Look for your Tapco mixer and see if it has any red X or error message. It might be that it isn't completely installed correctly. Also in the Device Manager at the top, click View and select Show Hidden Devices. Look for something under "non plug and play devices" (I think) called Mackie Subunit or some garbage like that. I'm traveling so I don't have any Mackie gear to plug in to verify. Anyway, this is the bit that actually interfaces with the Windows sound in Vista and Win7. You may have to manually install the driver as Windows says it doesn't need one. Right click and select update driver.
-Browse my computer for driver software
-Let me pick from a list of device drivers on my computer
-Click "Have Disk" and browse to whatever folder you dowloaded the Tapco drivers to.
May 22, 2012 | Tascam 2488 Portastudio Multitrack...
When I attempt to download photos onto my laptop I either get a message saying the USB hub cannot take the power level required or there is no recognition at all. Any suggestions?
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 20, 2011 | Vivitar ViviCam 8400 Digital Camera
How to connect Marantz PMD201 to computer to convert tapes
You have an analog tape recorder, so you need an interface which will allow you to plug it into your computer. This kind of interface is sometimes referred to as a USB Audio Interface. I use a Tapco Link.USB, and it works well, but there are many out there to choose from - you can use something pretty simple, nothing fancy needed.
The interface will plug into your computer via USB cable, and then you will use RCA cables to plug the PMD201 into the interface. When you play the audio on the tape machine, you should be able to select the "USB interface" on your computer as your "input device" and record on the computer. Watch on the computer recording software for input levels (meters that show sound is coming in), and set them to appropriate levels, not too low, not too high (if there is a red zone, you want to flirt with it only on the highest levels) ... don't hit "zero" if your computer shows zero as the peak level for input.
Final Cut Pro is far to complicated for what you are talking about doing. Many computers come with software already installed that will make simple audio recordings like this.
Please feel free to visit my website, rexark.com, for more information on audio and recording, as well as audio presentation and PA systems.
Good Luck!
Mar 04, 2010 | Marantz PMD201 Desktop Cassette Voice...
Tapco Link.USB Not Working Properly
ITS THE PORT OR THE HEADPHONES,PROBALLY THE PORT.
Nov 22, 2009 | Bob Mackie Tapco By Mackie LINK USB AUDIO...
Microphone too quiet
That's probably not going to work.
Mic level is extremely low compared with line level.
Your sound card is expecting a line level input.
It's simply not made to plug a microphone into (you must be using an adapter or two just to make the connection)
Look for a USB Audio Interface with XLR or 1/4" microphone inputs - these interfaces are pretty generic these days and easy to use ... just plug into your computer via USB and then plug the mic into the interface ... which has a volume control on it ...
I use a Tapco Link.USB ... and like it
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Oct 14, 2009 | Sennheiser E845S (3 Pack) Professional...
Peavey Escort 2000
You'll need an interface for your computer. An interface takes your microphone or mixer signal and transfers it via usb or firewire to the computer so the software recognizes the signal. There are many available and most come with software.
Try to find an interface that will include full-version software, not a demo. Some interfaces have issues with Vista, just check with your local store of choice to make sure it will work. One of my favorites is the Tapco Link.USB which includes a full-version of software with a pretty simple interface.
Oct 29, 2008 | Peavey Escort 2000 Microphone
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Open Questions:
See all Philips JackRabbit II (JR24CDRW) CD-RW Burner Questions
Philips JackRabbit II (JR24CDRW) CD-RW Burner Logo
71 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
