Question about HP Scanjet 8250 Flatbed Scanner
Document feeder How to use the automatic document feeder on HP ScanJet 8250
  • 192 Answers
You would face the taxt or images face up then you would scan it by using the program it came with if it did or any othere program the can scan documents and imagees on you computer. Make shure all conecsions are conect property and the software is installed.
Posted on Apr 21, 2009
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
What voltage should be read on each pin of the power adapter?
hello ,, this information is based on ScanJet 5400C - (C8517V) -- if yours is other p/n, let me know
North American use , C8517-84200, Low power AC power module (Wall Mount Type) - 100-120VAC, 60Hz - Detachable power cord not needed (USA, Canada) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
European use , C8517-84201, Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
Worldwide use , C8517-84201, Low power AC power module (Brick Type) - 100-240V input - Requires a 3-wire detachable power cord - For worldwide operation - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
i hope thsi helps -- if it does, please rate my service
Nov 13, 2010 | HP Scanjet 5400c Flatbed Scanner
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
HP c7280 scan 2 vertical lines
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
this fixed it for me
Sep 20, 2009 | HP Scanjet 8250 Flatbed Scanner
At scaning time show
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
HP ScanJet 5590 automatic feeder not working
Have you tried scanning in the flat bed mode? Does it scan okay? If the image is good, then there is no problem with scan module. Check your page settings. If the page size selected for scanning is smaller than actual size, there can be some peoblems. Try and scan with max size. Check if the sensors are dust/paper free. A small piece of paper (The small round discarded piece from Computer stationery) in the paper sensor can create trouble.
S. Mohan
Feb 21, 2008 | HP Scanjet 5590 Flatbed Scanner
Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Dec 07, 2007 | HP Scanjet 8250 Flatbed Scanner
HP Scanjet 8250 Flatbed Scanner Logo
424 people viewed this question
Seeker5211
Seeker5211
