Question about Samsung Televison & Video
Samsung syncmaster 711 mp will not turn on
I saw the file posted by: chris851 on Apr 19, 2008
samsung syncmaster 711mp will not power up/ switch on I have the same problem but I could not find the asnwer to what he has done to repair it. Where can I find that? Th on of light switches on and of and the screen stays blank
Samsung 711MP S, Type GH117TS 17" LCD TV. Same fault - will not switch on. Check the following, On the switch mode Power supply board - Electrolitic Capactors C241, C242 and C243 (470uF 25V dc) were faulty - They were bulging at the top of the can. Replaced these three and the tv starts up ok.
Posted on Jan 13, 2010
  • stevebasset Dec 05, 2010
    Fixed mine today - Thanks! Although I did notice one of the capacitors is a 1000uf 10v working.
    Also check that you replace them with high temperature ones.
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Where can i get the living solutions jumbo universal remote code for the samsung syncmaster 1701 mp tv
You should use the search remote code feature:
  1. Hold the device button you want to program for 3 seconds & release.
  2. Push & release the power button & the red light will remain lit.
  3. Push the CHANNEL UP button over & over slowly until the device turns off.
  4. When device turns off press OK button.
Hopefully that works for you.
Jan 07, 2015 | Samsung Televison & Video
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
Monitor turns on and off
Most monitors use switching power supply that can work from 90V to 270V 50/60Hz, you can see the label in the back of the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
It turns off automatically and then I cant get it back on.
maurice_camp Read the post I did for other Samsung 940MW's by clicking on the name "SyncMaster" above. You too probably have a "switch-mode-power-supply" that has gone into shutdown mode because it has detected a fault with some other circuit or even itself.
12fixlouie
Nov 09, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Changing in satelit TV from Radiocanal zu TV chanal
LOOK IN YOUR LOCAL PHONE DIREDTORY UNDER COMPUTER CABLE SPECAILIST, CALL THE AND SEE IF THEY MAKE THAT SWITCH FOR YOU, 99% TIME THEY CAN MAKE THAT HAPPEN FOR YOU ANOTHER OPTION IS A TV SHOP THAT BEEN IN BUSINESS FOR 20+ YEAR MAYBE TO DO ALSO.
ROD
Feb 09, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Televison & Video Logo
1,259 people viewed this question
Jerry Greenberg
Jerry Greenberg
