Home | Washing Machines | Washing Machine is not...
Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washing Machine is not getting cold water
By josephL on Sep 21, 2007
Not getting cold water. I think it might be the cold water solenoid. If this is the problem, how big of a job is it to replace the soleniid and where can get the parts and instructions. Estate TAWB600EQ Washing Machine.
Comments:
Sep 24, 2007
- Your assistance was helpfull. The probelm is I can't find the part. Any suggestions? How long should I plan on replacing the part? Are there any special tools needed?
Same Problem
Feb 24, 2009
-   Not getting cold water-   Guest
Jan 30, 2009
-   I have a Whirlpool LSW9700PQ0 washing machine. When I turn it on no water comes out or sometimes just hot water comes out. I think it is the valve. How do I tell and if so how do I replace it?-   jfontanella
Aug 01, 2008
-   My tub makes knocking noise and it seems to be very loose. It goes knocking from side to side. Also, I only have cold water for my first wash load. Please help. Senior Citizen-   Guest
May 21, 2008
-   Thank You!! I think that is what my problem is too. I appreciate the advice.-   Guest
Best Solution
posted on Sep 22, 2007
Helpful)
jsrock516
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 6684 votes
The solenoid comes as part of the fill valve assembly. It's fairly simple to replace, but before you attempt replacing the valve try turning off the water supply and disconnecting the hoses from the back of the washer first. Inside the valve assembly on the back of the washer are water valve screens. These screens can get clogged with sediment which will restrict or stop water flow. If you've never checked them or cleaned them before this could save you a little bit of repair time. Simply use some distilled vinegar and a cotton swap and thoroughly clean each screen. If the valve still does not produce water flow, the part number is 878761 an runs about $25. Let me know if this helps you.
Comments:
Sep 25, 2007
- If you provide me with the model number, I can see if I can trace the parts for you. You shouldn't require any special tools, either.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
is the ge whre550kww a good washing machine.
Answer
catolog of indesit wasing machine model w401wf
Answer
The machine has not finished it's cycle,how so I open the door?
Answer
the belt keeps coming off the drum
Answer
We just installed a washer model 28062. It is vibrating and shaking sometimes while running. It is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
