Question about Sanyo DS27910 27" TV
Sanyo 27 ds27910
Tv turns on and had a lot of blue tint to it sometimes it would lose all the blue and go green , now it comes on and has a 4 in pictuer from top to bottom on it than it goes off
    Genius:
  • 1,139 Answers
This looks like a power supply problem. I would advise checking the high and low voltage power supplies if you have a background in electronics. If not (I know this is not what you want to hear) take the set to a shop. I have said this many times and I'll say it many more times. TVs contain voltages that can kill you, not give you a bad scare, but kill you and I don't mean Hollywood dead, I mean really really dead. That being said this looks like the voltages have dropped so low that a full picture can not be mainained.
Posted on Sep 21, 2007
SOURCE:
I have a Sanyo DS27910 Flat Screen that is stuck on Video 1. My remote was lost in a move. I downloaded the manual but there does not appear to be a physical reset. Can you help me resolve this...
You can purchase the original remote for $20.99 base price.
http://www.replacementremotes.com/SANYO/Buy-FXRG-6450459313-TV-Remote-Control.html
Jun 10, 2011 | Sanyo DS27910 27" TV
I have a Sanyo ds19350 tv. It sometimes suddenly loses its signal or goes to snow. No sound. If I turn the tv off then turn it back on it will play for a few minutes then goes to snow again.This sometimes...
High voltage failure. Take off the back cover and look for the high voltage transformer. The transformer has high voltage at about 380 volts with low current, but it will give you a shock. Usually, there is a capacitor or two, hopefully, there is only one capacitor. Check the DC voltage across it - should be about 390 to 400 volts. If not, change this high voltage capacitor. Buy one bigger than the current one by three times.
Nov 24, 2017 | Sanyo DS27910 27" TV
After 5 minutes of being left on the screen turns green...I turn it off for about 1 minute and turn it back on and the picture is there....this repeats
The video board that connected to the CRT(tv tube).Have defective componnents,discribe the problems,ask the tv shop for an estamate.$100-150 to repair,i would repair it.More than that no.
May 08, 2010 | Sanyo DS27910 27" TV
Is a sanyo ds27910, purchased in 2003, a HD tv
No, it is not a High Definition (HD) TV.
Oct 14, 2009 | Sanyo DS27910 27" TV
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Sounds like either there's no connection to an antennea or your tuner is dead. Our TV has the same problem, so we took out the tuner and the games and dvd plays good still. So it's probably the tuner.
May 01, 2007 | Sanyo DS27910 27" TV
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
Sanyo DS27910 27" TV Logo
75 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
