Dryers
Problem for Dryers
Generic problem for all Dryers
Kenmore Electric Dryer Will not Run
By applejack on Sep 21, 2007
Recently my Kenmore has stopped running. I have checked the door switch and Start Switch which both work fine. In fact I can hold the Start switch down and it runs just fine and heats. Where would I look next to troubleshoot?
Same Problem
Sep 27, 2008
-   My Kenmore gas dryer model (#78932790), which looks similar to the Amana, has the same problem except it doesn't seem to heat up. It is not the starter switch or door latch. As long as you depress the starter switch, it runs. -   gramschris
Best Solution
posted on Sep 22, 2007
Very Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1050 votes
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Was this helpful?
Yes
No
Popular Solutions for Dryers
Questions and Unsolved Problems for Dryers
Answer
dryer will not heat and heating element is good.
Answer
how about a 100% dryer and tell me about the advs and disadvs
Answer
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what... (More)
Answer
my washer draining hose was loose and sprayed water everywhere including under the dryer and i... (More)
Answer
dryer wont heat up
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dryers:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14816
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
