Question about Macromedia Flash MX
Flush command buttons how to download it?
Hi my self bhavin shah i m ty bca student i want to make my project so pls help me i want flush buttons like.. add .save...right i want it
  • seiferts Nov 05, 2008
    hi!
    Can you give the codes on how to apply a command button with a GIF image?
    Scholar:
  • 151 Answers
Hi Bhavin, You search for software like button maker from free software download sites. Now if you r using VB or any other frond end application then save the above made buttons in *.gif format. Then you put that image in your button's image. If you r using java then put that gif image in to your button image. And if you want some animation in it then follow this link.. http://www.pageplugins.com/generators/crazy_text/flashgen.php Generate any flash text u want. and use it in your project.
Posted on Sep 21, 2007
SOURCE:
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Problem is to login in the railway reservation system
Sir,
Check this link
which software do u using?
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 26, 2009 | Computers & Internet
Regarding intranet chat system
so first you tell wt problm you have in ur projrct
Mar 13, 2009 | Computers & Internet
About antivirus project
Not the answer to your problem but an opinion by myself.Most viruses that are any good begin by shutting down your virus protector and your system restore. I personaly found that a program called deep freeze which is used to work on building viruses was the best course of action against getting one. But as i stated its my opinion.
Dec 05, 2008 | Computers & Internet
STUDENT 2007 error message
Is it a trial of office?
Will it allow him to save anything?
Try to activate the Office.
Nov 07, 2008 | Microsoft Office Home and Student 2007...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Payroll System
Well as it is a school project,, here
www.planetsourcecode.com
they have a lot of source code to do different things as well as completed programs, you can take a look there you may find stuff to give you ideas and examples of how to do things if you get stuck..
Please the people was kind to upload their stuff for free, please dont copy their work as say it is yours, they allow you to use it to make your own stuff better or to tech you how to do stuff. If you see something you like then please use it but modify it as well. If you need anymore specific help let me know ..
Jan 08, 2008 | Computers & Internet
Convergence settings
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Macromedia Flash MX Logo
89 people viewed this question
Top Macromedia Computers & Internet Experts
Peter Dragonetti
Folusho Adeyanju
Folusho Adeyanju
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
