Question about Panasonic SA-HE100 Receiver
Tv hook up!?
Hey yesterday i bought a cable that has the red, white, and yellow hook ups on both ends so i could hook my tv up into my big stereo for killer sound. But i hooked it from the back of the tv to the tv in hook ups on my reciever and it wont send any sound to my reciever. can someone please help im not the best with this stuff. thanks
    Genius:
  • 1,153 Answers
First you must be on the audio outs in back of tv set. then you must go into menu, if not already and change audio to varible output, or external speakers or just what ever yours say in menu. then you must turn receiver to the right inputs to get sound. Hope this helps.
Posted on Sep 21, 2007
SOURCE:
I just bought a Philips Smart WiFi Bluray Player BDP2105F7 and I cannot connect it to my old tv which is a sony triniton, I have image but no sound. There are two outputs on the dvd player but I have...
Your white red yellow cord is a Stereo sound + video cord. The red and the white ends are for sound the yellow end is for video - if your TV is not stereo it may not have the red and white it may only have one in which case you need to find an adapter from stereo to Mono to fit your red/white cable ends into a single connection on the TV. Or you can buy a home theater sound system and it will give the TV its signal and it will keep the stereo signal and broadcast it through the sound system.
Sep 15, 2017 | Philips Televison & Video
I cant connect my wii to my tv. can you give me instructions how?
Most TVs have a yellow video and a white audio and red audio input. The Wii comes with a cable to connect to a TV with a yellow, white and red RCA cable. Plug in the large block end of this cable to the Wii (rectangle block) and the other end into the TV using the yellow plug to the yellow input jack and the white plug to the white input jack and red to red. Select on the TV using the TV remote, the input where the Wii is hooked up. This is the standard way.
Apr 10, 2011 | Mitsubishi Televison & Video
I cannot hook up my game system to the tv and don't know where to start. help?
Hi
to hook up your console to your tv your console has to be switched on and in good condition,A lso you will be needing an A/V(Audio-Visual) cable, a cable that has to or three outlets normally red,yellow and white(Yellow is for video while white and red are the Audio outlets for stereo) These outlets go into an inlet on your tv and the other end goes into the back of your console
This enables you to see the picture and hear the sounds.If this is done then you are good to go.
Aug 20, 2010 | Televison & Video
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
Our Sony Grand Wega suddenly has a green-yellow tint.
IF IT IS HOOKED UP WITH COMPONENT CABLES (GREEN, RED, AND BLUE) FOR PICTURE AND RED AND WHITE FOR AUDIO, MOST LIKELY THE RED ONE IS NOT SEATED PROPERLY, CHECK BOTH ENDS THE ONE CONNECTED TO THE TV AND THE ONE CONNECTED TO WHATEVER THE SOURCE IS ( SATELLITE BOX, CABLE BOX ETC.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i connect my xbox 360 to a big screen tv like the box ones,with a rf modulator?
Hello there:
You will need the red/yellow/white video cables and just hook up the yelow and white up to the xbox and the other end yellow and white to the tv than turn the tv to channel 3 and this should work
best regards mike
Jul 30, 2009 | Dynex RF Modulator AV Signal Converter
I have a dvd player that I am trying to hook up to a sharp tv model number 25L-M100B. This tv don't have the necessary ports inthe back to plug dvd or anything up to it. It does have 2 in the front of
Hook the dvd player up to the front inputs usually a yellow and a red or possibly a yellow red and white depending if the TV is stereo or not.
Then on your remote, it the INPUT button and take it to "VIDEO 1" while your dvd player is on and you should get a picture.
Make sure not to mix the cable colors.
Yellow is video
White Audio
Red Audio
A lot of times there is only either white or red and not both. This is just Mono sound, it works, just not "stereo" sound.
Jun 01, 2009 | Televison & Video
Dish satellite system with two tvs and 1 hdtv cable
What are you splitting? Coax - just split the out to tv line. A\V cables or componet cables you'll need to split all wires (a\v- yellow and at least white, red to if you want stereo. componet- green, red, blue for video and red and white for audio.
Mar 12, 2009 | Televison & Video
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
Hooking DVD Player to TV
go to Wal Mart and buy a cable, its the cable with a red end an yellow end and a white end. Your TV does NOT support stereo sound, so you only need the white cable for sound, the yellow is for video.
Jun 10, 2007 | Symphonic WF803 DVD Player/VCR
Panasonic SA-HE100 Receiver Logo
226 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
