Question about Compaq Presario 5000 PC Desktop
My cd-dvd drive can read cd but can not read any type of dvd
  • 3,866 Answers
Dvd Servo is hosed . going to need to get a new one my friend..
Posted on Apr 21, 2009
Dvd will not burn to disc
replace the drive with a standby n see..
..contact ur System Admin/Vendor
Oct 27, 2009 | Compaq Presario 5000 PC Desktop
My E drive is not working. how can i fix it.
Have you tried cleaning the laser assembly? If your OS still sees the drive then it may just be having trouble reading.
Try this
First try to boot from your xp cd. If it fails to boot from the cd then your drive is screwed. If it does boot from the XP cd then ONLY try the following
Click Start.
Click Run.
The Run dialogue box appears.
Type devmgmt.msc in the run dialogue box and click OK.
Click on the plus sign next to DVD/CD ROM Drives.
Locate your DVD/CD ROM drive in the list of devices.
Verify the type of drive in your computer and that the type of media you are using is supported by the drive. Use the table below to determine the supported media types.
DVD+/-RW Read CD or DVD media, write DVD+RW, DVD-RW, DVD+R, DVD-R, CD-R, CD-RW media.
CD-RW/DVD Combination Drive To read CD or DVD media, and write CD media.
DVD-ROM Drive To read CD or DVD media.
CD-RW Drive To read and write CD media.
CD-ROM DRIVE To read CD media.
Try cd drive now before trying the next step
Click the Start button, right-click My Computer, and click Manage.
The Computer Management window appears.
Click Device Manager.
Click the (+) plus IDE controllers section.
Double-click the appropriate IDE channel.
The IDE Channel Properties window appears.
Under the Advanced Settings tab, verify that the transfer mode is set to DMA if available.
Click the OK button to save the change. At this point, you may need to restart for the change to become active.
Check to see if the drive will work in safe mode. I it still does not work Update the firmware for the optical drive.
Click the Start button, click Run.
In the Open box, type Regedit, and then click OK.
Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor.
Click the plus sign (+) next to SYSTEM.
Click the plus sign (+) next to CurrentControlSet.
Click the plus sign (+) next to Control.
Click the plus sign (+) next to Class.
Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
On the right side of the window, click UpperFilters.
Click Edit on the menu bar.
Click Delete, and then click OK.
On the right side of the window, click LowerFilters.
Click File, and then click Exit.
Restart the computer normally.
If all these steps fail then you will need to replace your drive.
Thank you.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
DVD Drive reads CD's but wont read any DVD's
Let me explain some things for you to understand what happened with the dvd drive.
A laptop (or desktop) dvd writter drive is actually build around 2 separate optical systems each specialised to deal with either a cd or a dvd type of disk.
A cd has normally around 650mb - 700mb.
A dvd has normally around 4,3gb - 4,7 gb.
But both disks have the sime size. So the larger capacity disk, the dvd has higher data density as related to the disk surface. Therefore because these disks are being read using laser diodes, each diode must be tuned to a specific frequency for each type of disk. A cd is read/written by a 860 nm diode (infrared) and a dvd is read written by a 630 nm diode (red). These are separate optic subcomponents (by the way, a blue ray disk and reader is called blue ray because of the diode that is used to read them, it's on 437nm and it's emitting blue light).
If your drive will read only cd's and fail to read a dvd then it means that the coresponding optic block for dvd reading has failed. The cd optic system will continue to function as it's not linked to the dvd part.
In this situations there is little to do to save your drive so you should consider the replacement or assistance in a service center for your problem. I'm sorry as we aren't able to fix this without having to dissasemble things and use some service equipment.
May 22, 2009 | HP Compaq nx8220 Notebook
DVD drive is not reading the Boot up disk
how many types of  bootable disks u hav tried,,,if d writer isdetecting d other ones den ur cd is faulty,hav u selected cd drive as 1st boot device or not
Mar 29, 2009 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Dvd ,cd worn't work
the driver should allready be installed with windows
What type of problem are you having with the drive?
Does the drive read CD's but not DVD's or niether one?
Did the drive work fine and suddenly stop reading just DVD's but still reads CD's most of the time?
Or is this a new drive that hasn't worked at all yet?
for CD use the driver should allready be installed with windows and almost never needs to be installed seperately
for DVD playback in windows XP you will need to install some sort of DVD driver into the system like power dvd or windvd or you can download DVD support for windows media player here : http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx#DVDDecoder
But I would need answers to some or at least one of the following questions before being able to help any further
1. What type of problem are you having with the drive?
2. Does the drive read CD's but not DVD's or niether one?
3. Did the drive work fine and suddenly stop reading just DVD's but still reads CD's most of the time?
4. Or is this a new drive that hasn't worked at all yet?
5. What operating system are you using?
I hope this info helps (please let me know if it does not)
Nov 20, 2008 | Toshiba Satellite A135-S2386 Notebook
Not reading dvd combo drive
HL-DT-ST RW/DVD GCC-4522B
h!, above is the model type of my combo drive dvd. It does not work anymore, it only reads a cd format but not dvd..can you pls help me with this..my personal email address hpbirco@yahoo.com pls send me ur answer to my problem..tnx
Sep 03, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Drive doesn't read DVD's, only CD's
ur dvd device lens is not working properly.......so that it only read cd-----
if u r drive is in warrenty....then replase it.....or go to any computer hardware shop may be they solve u r problem.......
best regards & best of luck..
Oct 01, 2007 | Samsung SD 616E (729507925578) Internal...
My dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Mar 26, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Compaq Presario 5000 PC Desktop Logo
129 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
