Question about Lenovo ThinkPad R51
I am using ibm R51 2888 , usb port is not working , power is coming in usb port but not detecting usb when attached
  • Lchaim897 May 09, 2009
    I get power from the USB, but the computer doesn't recognize the device. What gives?
  • Grand Canyon Tech
    Grand Canyon Tech May 11, 2010
    Does it detect other devices?? Did you try other USB devices before calling the quits?
2 Suggested Answers
md_ehsan_1
  • 255 Answers
SOURCE: I have a problem with my USB's ports.
reinstall *********** board chipset drivers, to fix this problem.
Posted on Jun 23, 2009
My ibm r50e usb ports are not wrkng pls smebdy hlp me?
When you say they are not working...
Is there power to the ports (when you plug something into them does the activity light on the device come on?
Are the defective ports the primary ones attached to the motherboard or expansion ports on the front of the case?
Is it a windows o/s failing to recognise them?
If the primary ports on the back of the PC aren't working try deleting all USB branches in the device manager on your windows PC and reboot - they should all reinstall automatically...if they don't your m/b is probably defective.
If they are expansion ports check the main ports on the back of the PC.
It is possible to kill a m/b by plugging daft stuff like fans/lights and remote control missile launchers into your USB ports :-)
Oct 03, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I get disk read error when I try to boot it up.
hi there, here are possible solutions to your issue
1. make sure first that your computer would be able to identify your harddrive. you can check this one by going to the setup utility page. upon pushing the power button quickly tap the F1 key or F2 key. then check your Harddrive if motherboard was able to detect it.
2. make sure that there is now usb flash drive or external drive attached to your usb ports when booting up your computer. sometimes if you have this devices attached to your usb this error happens when booting up.
3. Power on the computer and keep on tapping F8 key the moment you push the power button. select safe mode once oyu enter the black screen. if same error occured. then, ou need to use the recovery disk that came with the system and restore the computer back to original factory settings.
Apr 07, 2010 | IBM ThinkPad 600E 2645 Notebook
I'm using IBM G40. my USB 2.0 Ports are not working from a long time ago!!! could you help me plz
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
Nov 22, 2009 | IBM ThinkPad G40 Notebook
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
My USB ports suddenly quit working on my IBM Z Pro 6221 59U
Check the actual ports, visual inspection. Look for consistancy of the pins, and guide. If one is bent or missing, that can short out the ports, or blow out the integrated circuit.
If you are using a usb keyboard, try to start up and go into the setup using the keyboard. If you can, the driver for the ports might be damaged, causing the problem in windows, but not in the bios startup.
You can purchase a usb board that can give you new ports, and deleting the usb hub from the hardware manager (check help) and re-detecting the device might repair a damaged driver.
Sep 23, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Jun 23, 2009 | Lenovo ThinkPad R51
Asus P4P800-X USB Problem
Maybe your USB port on your computer is model 1.0 while the hard drive is a 2.0. That would cause it not to read it. Check your system information and see what model your USB ports are.
Mar 17, 2009 | ASUS P4P800-X Pentium Motherboard
IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Jan 30, 2008 | IBM ThinkPad T41 Notebook
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
Computers & Internet Logo
461 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
