How use RCA F27634ET front panel button
How can I setup to VCR my RCA F27634ET without remote control
Crikett- that won't work.
Not being able to get to Channel 00 without the remote was a design flaw of this model from the day I bought it back in 1994. Go buy a universal remote control so you can get to the Input function.
Posted on Jul 11, 2009
    President:
  • 1,779 Answers
I believe if you just use your channel down button until you come to video1 (ect) I think that's it.
Posted on Apr 21, 2009
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
I'm trying to use the RCA rcr311thm1 remote to
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    CODE SEARCH METHOD
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
May 06, 2012 | RCA Televison & Video
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
Need instructions for codes for jumbo remote for symphonic tv with vcr
Hello
Setup code for Symphonic TV/VCR with Jumbo remote control is: [002].
There is no setup codes for TV/VCR combo with RCA RCU600M remote control. OK.
Aug 14, 2011 | RCA RCU600M Remote Control
The small black rca universal remote lost code book and need a code for a emerson tv
Hello
There are so may RCA model remote controls with black colour. If you send the model number of your RCA remote control I will try to send the codes for Emerson. Its model number will be either on its front or back cover, or inside the battery stop lid. Anyway I hereby give you some universal remote control codes for RCA with Emerson TV. Just try them.
011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064, 065, 067, 075, 076, 079
Four digit universal remote codes for RCA are:
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
Jun 23, 2011 | Televison & Video
I can't get my universal remote programmed for my RCA tv model # F25648. Do you have any sugestions?
Hello
Three digit universal remote codes for RCA are:-
002 021 011 102 211 302 312 318 320 406 409 411 420 502 511
514 519 601 702 711 719 809 811 901 909 911 912 914
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote code for RCA are:-
Direct Code Entry
NB: Switch OFF and switch ON your TV with its front panel power control switch each time [NOT WITH REMOTE CONTROL HANDSET], before trying an other code.
OK.
Jan 06, 2011 | RCA F25648 25" TV
I have no remote how can i get to the menu without the remote
Look on the front for manual controls,should have a button said Menu.No,button on the front controls said Menu,than u need a remote to get in the menu sorry.Try website like Remotes.com to buy an exact to the original remote or very close compatible one.
Oct 13, 2010 | RCA DRC6355N DVD Player/VCR
Big Blur when i turn the tv on
Hi!
First of all please check the following things:
Press the TV button. Make sure the TV is plugged in. Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else. Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions. The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Front Panel Block in the Parental Control menu and press OK to uncheck the box. The TV might be performing a periodic diagnostic check. Wait for a few minutes for the TV to turn on.
If still the problem persists then check the following:
Maybe the cable/air function is set to the wrong position. The channel might be blank — change channels. If you’re watching your VCR and it’s connected with coaxial cable to the CABLE/ANTENNA jack, tune the TV to channel 3 or 4 (whichever channel is selected on the 3/4 switch on the back of your VCR). Also check to make sure the TV/VCR button on the VCR is in the correct mode (press the TV/VCR button on your VCR). Check antenna connections. Make sure all of the cables are firmly connected to the jacks. Try adjusting sharpness function to improve weak signals. Closed-captioning might be on. Check Closed Caption in the Setup menu.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
Electro Med Services...
