WINDOWS XP WON'T LOAD TO HARD DRIVE
My Hard drive crashed and I have replaced it with a WD320 and now when I try to load Windows XP PRO it won't load the ntfs files and a bunch of other files and when it trys to load off the HD it says the Bootmgr is missing. I am useing a true Windows disk I have a M7VIG 400 rev 7.1 board 1 gig of ram the hard drive is showing in the bios and it trys to load from the HD but comes up with the bootmgr is missing and no I didn't make a reboot disk I even tried to load vista and it won't even see the cd rom disk in the cd rom drive what am I doing wrong or miss doing?
  • 62 Answers
1) If you are trying to install from a bootable disk and trying to make a fresh install, you will not come across this error.
2) If you are trying to repair the existing installation, you might need to use FIXBOOT command and try. Please refer the below link before you try this.
http://support.microsoft.com/kb/314058
Posted on Apr 22, 2009
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Panasonic Toughbook won't load Windows XP CD
You can check to see if the hard drive is dislodged, but other than that I don't know what to tell you. If you know the drive is functioning correctly then your motherboard is probably dead.
Jun 25, 2012 | Panasonic Toughbook CF-30 Notebook
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Emachines W3619 won't load ntldr
Take a windows XP CD, Switch on your PC and go to "BIOS" menu and select "Boot From CD/DVD" whichever is applicable for your pc.
Now insert the Win Xp disc i drive and start PC, Boot the Pc From CD Drive and you shall get the Blue screen of windows Installation. Restart the PC by hard pressing the power button for 30 secs.
Now you will be able to login to windows.
Dec 02, 2011 | eMachines W3619 PC Desktop
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
I cannot load windows xp pro
Go to BIOS and disable "NATIVE SATA SUPPORT"
Mar 20, 2009 | HP Computers & Internet
I have a gateway lb3 500 ancient 98se i tried to load xp pro and it crashed i cant seem to even get a 98 startup disk to work to recover it . how can i recover it to load the xp pro onit
Try running linux on it. Linux will run much better on older hardware. Depending an the specs of the system, it may not be able to handle running windows. Try ubuntu (www.ubuntu.com). If it used to run Windows XP or 98 and it wont now, try checking the hard drive. It may be corrupt. You can find hard drive check tools all across the web, google for drive fitness test by hitachi, it works great. Burn to a disk and boot to it on the older machine and do a full advanced test on the drive.
Dec 07, 2008 | Computers & Internet
Crashing during Windows Setup
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
Sep 17, 2006 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
