Question about BenQ FP937s+ (Silver) 19" LCD Monitor
Have a solid line across screen - BenQ FP937s+ (Silver) 19" LCD Monitor
  • BenQ Master
  • 3,866 Answers
Try this. Run some dianostics on your video card itself.. If all else fails you probably got some dead pixelation, You might need to send it back to the mannufacture for replacement or warrenty.. But try the video card first to see if that shores up the problem.. You might have some bad video memory but if the monitor has the line before your computer even starts up then its your monitor
Posted on Apr 21, 2009
I have a solid black line across my 32' Element tv with sound,
If the line is about an inch thick, it might be due to a bad CCFL in the panel.
Jun 09, 2012 | Element Electronics FLX-3211B 32 in. LCD...
I have a Flat screen Sony Bravia KDL-46S4100. Lines go across the screen horizontally about 6 inches apart. There is distortion especially on the right side mostly on lower right. What needs to be done to...
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Apr 02, 2010 | Televison & Video
I have a yellow line going across the top of my screen
open the back of the tv, put a heavy blanket over the screen and adjust the knobs inside the tv until the lines are bright, solid and straight
Dec 10, 2009 | Televison & Video
Solid lines print across the paper
It is usually caused by the drum. The lines are vertical? perhaps the drum was scratched and needs to be replaced.
If you replaced the toner before the lines appears, the printer needs to be cleaned.
Nov 02, 2009 | HP LaserJet 4 plus Printer
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Solid white horizontal line
ha ha ha ha ha ah ha ah aha aha a a hah
May 04, 2008 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
BenQ FP937s+ (Silver) 19" LCD Monitor Logo
251 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
