Question about Hotpoint (HSM25IFTSA) Side by Side Refrigerator
Hot point side by side excess frost????
First notice freezer was not working properly... after following a couple of suggestions found here i did notice there was a air blockage... did remove the panel inside the freezer..and there was this HUGE block of ice..so i did use a couple of tools to melt the ice...Fridge was working great till today i notice air flow is poor and panel feels like a rock so i assuming is a block of ice again....please help!!!!
  • 1 more comment
  • BSE Apr 21, 2009
    Thanks a lot for the help but sounds confusing ..this unit has a digital control..i did turned it down to "0" (off) a couple of times and the compresor (fan) stops...What do i do next???
  • BSE Apr 22, 2009
    Did remove the mother board and looks in good shape... fridge did worked fine for about a month...sound like fridge is not defrosting...What else can i check????
  • miralu50 May 13, 2009
    I have a side by side HotPoint. Frost is accumulating in the mid section of the freezer. Washed it off with warm water only to have it back again in a day. Refrigerator side not cold enough to keep milk from going bad. Is this fixable? Is there ice inside? I suspect Fridge is about 20 years old.
  • Hotpoint Master
  • 4,654 Answers
When you continue to get ice build up like that it causes me to think that either the freezer section is not draining properly or defrosting regularly. Most times when a refrigerator works properly they can dehydrate moisture very well and send the melted water down a drain to a pan next to or on top of the compressor. If you need my help let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
seabreezehvac@yahoo.com
Posted on Apr 21, 2009
  • John Tripp
    John Tripp Apr 21, 2009
    If you are ready to check the defrost heater, and defrost termination switch you will need to unplug and open the back. Take one wire off of defrost element and use a multimeter to check continuity through the element. You will need to check the termination switch also. If your refrigerator is the model listed above your post it does not have a defrost timer. It has a mother board on back of refrigerator. If you have no bad results inside the back wall of the freezer, we need to consider that the mother board is bad. With power unplugged remove the board and examine both sides for burn marks. Make sure the model number above your post is correct, Thanks Sea Breeze
  • John Tripp
    John Tripp Apr 22, 2009
    If the elements are good connections good and defrost termination switch. Then the drain may be the problem. Did you see water down near the compressor? I'm sending you to another site where a refrigerator was poring liquids into fresh food section. Because you are getting ice blockage every time I believe your drain may be blocked, Click on link below and study it awhile and try to see maybe what is stopping the water from going out and causing this buildup. Thanks, Sea Breeze
    http://appliancejunk.com/forums/index.ph...
  • 358 Answers
There's probably a bad defrost timer(located where the cold control is or behind the bottom front grill in the refrigerator.You can turn it until clicks and the compresor stops and if is ablock of ice in the frezer coil you heard the defrost water steaming when it hits the defrost heaters ,if not the heaters are bad or the defrost terminator is bad.You can check the heaters for continuity if they're ok the defrost terminator is bad ,but most of the caes the problem is with the timer.
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Frig not cooling
check evaporator fan to see if it is blowing air over to ref. side.you also could have a defrost problem.if you notice frost forming on the back panel inside freezer then it is a defrost problem.all parts are in freezer that need to be checked.
Mar 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
GE Side by Side stopped cooling
This sounds like the defrost heater is bad or dead. The refrigerator will not cool because frost is building up on the evaporator coils in the freezer section and the fan can no longer push air past the coils. You will find that the freezer will build up with frost.
If you are brave enough, remove the cover in the freezer and you will see the coils are completely covered with frost (ICE). At this point with the refrigerator unplugged ( remove food). get a hair dryer or heat gun and melt all the frost. You will notice a heating element ( looks like a tubed light) -element will looked burnt out.
Replacing it at this point is easy. Before you start though, try to get the manual for your system and call around for a local appliance parts store to see if the part is readily available.
Nov 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint (HSM25IFTSA) Side by Side Refrigerator Logo
128 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
