Question about HP PSC 2210 All-In-One InkJet Printer
Problems with Printing
Greetings: I have developed a problem with the way this printer prints. What happens is this ... When I print a document from in my computer (such as a WORD document) -- I get the top two inches of the page printing correctly, and then, the rest of the page (all the way to the bottom) is in the BOLD AND HEAVY PRINTING that is so overprinted it can barely be read. I am ready to throw this thing through the window! P.S. When I make a photocopy, this does not happen. Also, there is no BOLD settings selected in my WORD program. So, it is nothing I am doing. I tried to fix this by unplugging the printer, and by changing the cartridge -- nothing helped. HELP! Any suggestions? Kentroversy Buffalo, NY USA
    President:
  • HP Master
  • 2,022 Answers
Try with reinstalling the printer drive and see bye.
Posted on Sep 22, 2007
  • mukhtar21 shaikh
    mukhtar21 shaikh Sep 26, 2007
    pls try with chane the cable also.
    bye
SOURCE:
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
Ricoh mp5500 printing light copie
Hello!
Is it only in copies? If so you need to clean the all scanner (glasses ans mirrors)
If that happens also when you print it could be one of this problems;
-The laser (durt)
-The Magnetic Roller (in the development unit)
-Or the Developer.
The question is: When was the last time that you did a service maintenence??? Maybe you need to do that.
See you!
Aug 15, 2011 | Ricoh Office Equipment & Supplies
Pages come out pink only when printing in colore
The magenta developer is bad.
The developer drive on this printer rotates in both a clockwise and a counter clockwise direction to turn the developers.
When printing black, ( i cant remember which direction it turns, ) only the black developer turns.
When printing color, the developer drive turns the opposite direction, engaging ALL 4 developers.
( the developers are the multi colored bars you see when you remove the image drum unit.)
This is why you do not get the pink output when printing only black.
your choices are to set the printer to only print black and white. ( you can do this in the printer properties for your print driver). or you will need to replace the magenta developer.
Feb 07, 2011 | Dell 5100cn Laser Printer
Paper feeder prints one sheet and sends several blank sheets out. It is also prone to develop a paper jam and envelopes do not feed properly
HP designed a quick and easy tool that diagnoses and resolves many printing problems: The HP Print Diagnostic Utility. HP recommends that you download and install the Print Diagnostic Utility any time you need to troubleshoot a printing problem.
Nov 04, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
After printing he print headaliengment
Greetings!
I dont know the kind ot printer that you have, but that happen when the printer was set to that setting. Just open the printer icon/setting then properties find the setting and removed that kind of action.
Thanks
Nov 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing problems
Greetings,
In your case it sounds to me like you need to have the print head replaced. The Kodak team can fix you up quickly. Just call the 800 421 6699 number and let them know of your experience. Tell them you have already tried the fixes they might suggest. They will get you another print that will set you on the road to enjoying your printer.
Talk to you soon.
Ron Baird The friendly Kodak guy
Sep 24, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Diagonal shading problem on monochrome print
I would try cleaning the lasers with the brush inside the door. If that fails, you might try looking at the developers.
Mar 20, 2008 | Ricoh Aficio CL7200 Laser Printer
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
Mar 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
