Question about Envision H191W Monitor
The controls for the screen display keeps popping up
The chart for the screen display keeps popping up without notice and we can't get it off. How can we get it off and keep it off?
  • Envision Master
  • 3,866 Answers
Try to see if you got a button that is sticking.. 9 times out of 10 that is the solution but if not you might have a bad controller board in the monitor itself that may need to be replaced..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 21, 2009
Why does my popup open out side my screen
Check your display settings. Do you have multiple monitors? Which operating system are you using?
Jun 24, 2014 | Microsoft Windows 7 Ultimate for PC
St4000 pops into standby
Hi
This is almost always caused by a dirty connection at the standby contact. If you're handy with electronic repairs, take the control apart and clean the circuit board for the contacts with silicone spray (safe for plastics) and a Q-tip and reassemble. Works 99 44/100% of the time.
Hope this helps.
-Steve
Apr 09, 2014 | Raymarine Smartpilot Autopilot St6002 S1g...
Resolution notice
Your monitor is not running in its native resolution, so there is notification to change your display resolution, then you have to check driver for your video card. Upgrade the driver fot your video card. Where will be the setting to change to 1440 x 900.
Nov 08, 2013 | Envision G19LWK Monitor
The "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
=== If you see mis-aligned pins then please power off the set before making corrective action. ===
============== Here's a textbook instruction from Mitsubishi
If the New Device Found Screen Displays No HDMI Control Option If the New Device Found screen shows no option for HDMI Control, one of these conditions applies: • HDMI Control is turned off in the menus of the new device Action: a. Highlight EXIT and press ENTER to close the New Device Found screen. b. Display the device's setup menus and enable the device's CEC capabilities. c. Wait for the TV's New Device Found screen to appear again. d. If the New Device Found screen does not appear, power off the device. Power on the device and wait for the New Device Found screen to display with the HDMI Control option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
Jan 05, 2011 | Mitsubishi WD65737 65" DLP TV
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
Monitor keeps displaying model and serial information
@ baller98_199; did you ever get a solution to this? I'm having the same problem with the same monitor!
Mar 13, 2009 | Sony SDM-HS75 17" LCD Monitor
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Resolution notice keeps popping up every thirty seconds or so. very annoying. this happens only when using cd rom game diablo. wants me to change to 1280x1024, which my computer is set at now. otherwise...
When you load the splash screen of Diablo enter into settings. Make sure you have the game set to the screen resolution you want.
For the system. Open display properties. Click Settings, click Advanced, click Monitor. (Most games require 60 hertz) to run correctly. Change your monitor to 60 hertz. Than click the Adapter tab. Click list all modes. Move the slide bar to your normal screen res with 60 hertz. Click ok at every screen as you back out od display properties. That should stop your game from popping up.
Feb 26, 2008 | Niko 1920R Monitor
Enlarged Picture
yes it is fixable. this problem is due to more supply is going to h/output stage. please check 1 power supply for more voltage then normal. 2 component failure or settind in horz. stage to be checked. 3 print crack in h/output stage you can not control from remote control.
Sep 27, 2007 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Envision H191W Monitor Logo
222 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
