Question about Saeco Incanto Classic Espresso Machine
Grimac ZOLA II - NO HOT WATER !!!
My Grimac ZOLA II - 2grp, Electronic - Espresso Machine
It has steam in both steam wand !
it can extract espresso in both Group Head !
but NO HOT WATER !!!
What is wrong with this machine and where can I find a service manual for this unit?
    President:
  • 1,618 Answers
The problem is either the switch that controls the solenoid for the hot water valve, or the solenoid itself. Place finger on the solenoid coil and press switch if the solenoid is working you will feel the nucleus when it engages. If both switch and solenoid are working then the pipe connected to the solenoid from the boiler is clogged.
Posted on May 22, 2009
I have an Ascaso Steel Duo Professional semi-automatic espresso machine - the steam wand is restricted. how do I remove it to clean?
Hi There, If your ascaso steel duo is not producing steam,
Could be that:
The thermoblock may be blocked - Try descaling.
JURA descaling tablets
Steam wand may be blocked - try removing steam nozzle/steam wand and submerge in hot soapy water.
May 01, 2011 | Ascaso DUO PROF Stainless Steel Espresso...
Zero steam from steam wands. No pressure.
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
Apr 14, 2011 | La Marzocco Linea Series Group 3 Espresso...
Ok...I got heat. Hot water from wand. Steam from wand. Machine is cleaned 2 times a year with decalcifier. Screen cleaned every other month. Now...espresso come straight thru like there is no pressure...
The pressure is from zero to the opening pressure of the OPV. This should be about 10 bar when the OPV is cold. When the OPV is hot, the OPV spring is hot and a little more flexible. The OPV opens at about 8.5 bar when hot.
When the wand valve is open, you can get a lot of steam or water with not a lot of pressure in the boiler.
Take the lid off the reservoir and watch the hose from the OPV. It's the short hose.
Pull a shot with less than usual coffee in the basket.
If you see water flowing from the hose, the OPV opened.
If it did not open and there is little extract in your cup, buy a new pump.
Oct 15, 2010 | Rancilio Silvia Espresso Machine
Why does steam wand on dualit espresso leak
The wand can leak if the rocker switch is not in the UP position.
In MIDDLE position it will try to deliver hot water.
In DOWN position it will try to deliver steam.
The thermoblock in this unit is actually a 3-way valve, of which two positions route water from the boiler directly to the wand. The 3rd position (UP) routes hot water (but not steam) from the boiler to the group head.
Try holding the switch in the UP position by hand when making coffee. If the machine still pushes water through the wand then you will have to replace the switch inside the machine that is activated by the rocker, or the valve it operates.
Please let me know how it goes.
graham dot r dot leach at gmail dot com
Oct 01, 2010 | Dualit Espresso 889 Espresso & Coffee...
I HAVE A GRIMAC MACHINE CAN I PUT A CAPPUCCINATORE?
Their is a cappuccinatore for every machine that have a steam wand
Dec 04, 2009 | Saeco Royal Professional Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Hamilton Beach Espresso Machine
I have had similar issues with my 40729.
Assuming that when you turn on the steam switch, the steam light goes on and then off when up to temp:
I have resolved this by filling my steaming pitcher with boiling water, remove the end-cap from the frothing wand and soak the end of the steam pipe in the hot water for several minutes. Then fire up the steam and blow it out. if the obstruction is more serious, then you may need to unplug the machine and run a thin and stiff wire ( like a guitar string ) up through the wand to break up the clog.
This unit uses one heater for both the extraction and the steam, so if you are getting extraction then the heater is good. You may also have either:
  • a bad needle valve in the steam knob on the right.
  • a bad thermostat that regulates the heater temp when you turn on the steam switch.
Jan 12, 2008 | Hamilton Beach 40729 Espresso Machine
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
324 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
