It is not defrosting. timer ,element , limit switch maybe issue. find defrost timer advance it see if compressor and fan quit running. when you advance this it should start defrost mode, which turns on the heater, which stays on till limit switch opens or timer advances, most are on 12 hour cycles
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_4ed9a6c8e57209e6
SOURCE: MAYTAG,AUTO DEFROST PROBLEM
The defrost timer is normally located in the area of the temperature controls. There is a clutch head knob on the timer which can be rotated clockwise very slowly until a click is heard. Wait 30 minutes and defrost should take place in that time period. If defrost does occur and the system does not restart cooling, rotate the knob more and you will hear a second click and the compressor should start .
If the system restarts in the cooling mode in 18-22 minutes the defrost timer is good and the problem is more than likely in the defrost heater circuit.
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
SOURCE: ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
SOURCE: GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
