Machine turns off?
Vcr will play about 16 sec then turns off will also do this rewinding or ffwd
  • 48 Answers
Soulds like the power supply has leaky caps causing the incerased current to drive the motors to be enough to turn the unit off. It's also possible the mode switch is dirty, if you are confident, you can try and clean it.
Posted on Apr 21, 2009
Cassette Recorder play problem
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
Set the timer to record
Do you have the remote which came with it? Most VCRs of the last 10 years require the remote to setup a timed record, or for that matter, most of the advanced functions- beyond play/rewind/ffwd, etc.
Assuming you do have the remote, and the correct time is set, and the timed record properly setup, some VCRs require a the On-Timed-Record button to be pushed. This sets the VCR in a wait mode, until the time set for the recording to begin.
Consult your owners manual- an online manual may be available if the printed one is missing.
Mar 04, 2009 | Sharp VC-H812U VCR
Scrolling message will not go away
press play for 5 sec/ should shut off
if not
try with no tape in press play and rewind at same time for 5 sec
hope this helps.
thanks,
daniel.
Jan 13, 2009 | Panasonic AG-520G 20" TV/VCR
Code 3L117C ???
None that I could find. Trash time for this Sony
Dec 10, 2007 | Sony SLV-798HF VHS VCR
Accessing the menu and timer recordings
Oh boy! Most late VCRs must have a functional remote to get to the advanced functions such as setting time, programming, etc. The front panel buttons only have stop/play/rewind/ffwd/eject and so forth. Either obtain an exact remote, or one of aftermarket universal remote boxes which have menu functions.
Nov 14, 2007 | Curtis CMV41001 VCR
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
