Question about Refrigerators
Ice Maker It either overfills or the water cycles before the ice is dumped. This causes a huge pile of ice under the icemaker fill area
  • 5 more comments
  • sold Dec 20, 2007
    Ice maker keeps making ice and over fills
  • Anonymous Apr 04, 2008
    This ice maker continues to feed water after the tray is full and freezing the
    cubes, this occurs when the freezer door is opened, The GE tech has re-
    placed the ice maker twice, he recently installed a small plastic part on the
    fill mechanism to catch the water spillage. We are waiting to see the results of this fix now.
  • kurtzon1 Jul 28, 2008
    can't stop ice maker
  • Anonymous Aug 19, 2008
    A plastic piece is broken that causes the water to overflow
  • jplae0308 Oct 05, 2008
    What is the plastic piece called?
  • craftworks10 Jan 04, 2009
    ice maker
  • dirtj00 Feb 01, 2009
    Same probelm. Any fixes?
  • 473 Answers
Replace the ice maker.
Posted on Oct 06, 2007
Could it be the water inlet valve is broken? It looks easy to fix yourself
Posted on May 07, 2009
SOURCE:
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Ice Maker does not dump ice
IF THE ICEMAKER IS TURNING AND NOT DUMPING YOU NEED TO REPLACE THE ICEMAKER ***.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Samsung Refrigerators
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker leaking
shut off the water going into the unit if it stops doing it then your valve is bad as it is leaking by and filling the im too much
May 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
817 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
