Question about Carrier Heating & Cooling
Require carrier 19xl strip down service manual with procedures and tolerances
Cam installation
Cam installation requires a partial disassembly of the Sporty's motor and as Sportsters have 4 cams!!! the camshafts have "timing" marks and this procedure is critical to proper engine operation. I urge you to consult a factory H-D service manual or qualified individuals before attempting to do engine/performance work as many clearances and tolerances will HAVE to be checked and verified.
Sep 25, 2010 | 2001 Harley Davidson XL 1200 C Sportster...
How do i change the power window motor on the drivers door?
Aztek, Rendezvous 2001-2005 Window Systems - Power Windows Removal & Installation
  1. Position the window in the full down position.
  2. Remove the trim panel.
  3. Remove the water deflector.
  4. Remove the outer belt sealing strip.
  5. Remove the window weatherstrip.
  6. Loosen the bolts to the clevice clamps.
  7. Remove the window from the outside of the door.
To install:
  1. Position the window between the inner and the outer door panels.
  2. For front window, point the lower front corner of the window down and pass through the belt opening. For rear window, point the lower rear corner of the window down and pass through the belt opening.
  3. Align the edges with the window weatherstrip channel.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Turn the window to a horizontal position and align the window with the clevice clamps.
  5. Tighten the clevice clamps bolts to 97 inch lbs. (11 Nm).
  6. Install the window weatherstrip.
    WARNING Do NOT allow the sealing lips on the outer belt sealing strip to roll over and point downwards. If this condition is present the window will not raise properly.
  7. Install the outer belt sealing strip.
  8. Install the water deflector.
  9. Install the inner trim panel.
Window Motor & Regulator
  1. Remove the door trim panel.
  2. Remove the water deflector.
  3. For rear window, remove the rear speaker.
  4. Disconnect the window from the regulator carrier plate.
  5. Position the window in the full up position and tape it to the window frame.
  6. Disconnect the electrical connector from the window regulator motor.
  7. Loosen the bolts on the window regulator motor.
  8. Loosen the bolts on the window regulator rail.
  9. Remove the window regulator, lifting up and out from the key slots on the door inner panel and through the access hole.
To install:
  1. Install the window regulator bolts half way into the window regulator motor and the rail.
  2. Position the window regulator rail through the access hole first.
  3. Position the window regulator motor through the access hole.
  4. Install the window regulator into the key slots. Attach the regulator to the motor and the rail. Secure the regulator with bolts and tighten the bolts to 97 inch lbs. (11Nm).
  5. Remove the tape and position the window to the regulator carrier plate.
  6. Connect the window to the regulator carrier plate.
  7. Connect the electrical connector to the window regulator motor.
  8. For rear window, install the rear speaker.
  9. Install the water deflector.
  10. Install the trim panel.
Hope helps (remember rated this).
Jul 16, 2010 | 2002 Buick Rendezvous
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Alignment error
Try Repositioning the Encoder strip.
Oct 12, 2008 | Dell 942 All-In-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Carrier Jam
I loaded to new cartridges into the printer1.gif, switched it on, cartrigde went from one side to the other with a bang, error on printer reads, clear the carrier jam, cn you help?
ed
Jan 11, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Carrier jam
This fixed the problem for me : found it on the Dell support website:
  5. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    new_note.jpg Note: There is a small slot on the back of the ink cartridge carrier, into which the encoder strip fits.
Jan 04, 2008 | Dell 924 All-in-One InkJet Printer
Error 0502
Re-position the Encoder Strip on your all in one Printer To re-position the encoder strip, perform the following steps: 1. Remove the power cord from the unit. 2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located. 3. Gently slide the ink cartridge carrier to the middle of the printer. 4. Gently move the top part of the printer belt to the right. 5. Using an index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier. NOTE NOTE: There is a small slot that the encoder strip fits into, which is going to be located on the back of the ink cartridge carrier. 6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly. 7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip. 8. Once the encoder strip has been re-seated, close the lid to the unit. 9. Re-connect the power supply to the All-In-One. 10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear. See attached pictures, one for an out or place encoder strip, the other for a well placed strip. Other faults that can bring up this error is a carriage rail that needs cleaning and oiling (so you might want to do that while your inside the thing), and also obstructions to the paper ways. Try removing paper jams, and put the printer upside down to shake loose anything that might jam the mechanism. Good luck!
Jun 06, 2006 | Dell A940 All-In-One InkJet Printer
Heating & Cooling Logo
431 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
