Question about Garmin GPSMAP 76Cx GPS Receiver
Garmin Maps I would like to know if it is possable to load Garmin Bluechart to a Magellan triton, should I replace the image file on the sd card with the Garmin image file? Also the answer to my 76cx two maps to one sd card, can I install Bluecharts and roadmaps as one file?
  • Garmin Master
  • 638 Answers
No, Garmin maps will not work on a Magellan Triton.
Yes, you can install Bluechart and CityNavigator onto one SD card. Inside Mapsource, select the Bluechart maps you want, then switch to CityNavigator and select the maps you want from then, and then send all at once to the GPS unit. If you send Bluechart maps, and then CityNavigator, the CityNavigator will overwrite the Bluecharts. This is why it must be done all in one step.
If this solves your question, please remember to come back and rate the answer.
Posted on Aug 06, 2009
jonniewalker
  • 1029 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
  • 373 Answers
SOURCE: International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
Posted on Jan 29, 2009
SOURCE: Maps Updates
where can i go for updated free magellan1200 maps to update my gps
Posted on Mar 14, 2009
  • 35 Answers
SOURCE: Can I remove the preloaded maps in my Garmin nuvi
To my knowledge you cant remove preloaded maps,but word of advice when purchasing other maps,get them on a Memory Card instead of preloading on your GPS,reason being,if you deciede on a different GPS in the furture you can then use the same maps which are on the Memory Card.
Posted on Sep 24, 2009
Testimonial: "Thanks for your comment. Not the info I was hoping for (ie preloaded maps). A good suggestion; re. memory card. Thanks once again"
SOURCE: How do I get Malta Maps for Garmin Nuvi 200w
there are still no released maps for Malta. You have to buy them from a local company
Posted on Feb 06, 2010
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
I want a blank map of ireland to print
can u email me at raj@npconline.in
I have balck maps of IReland
Regards
Raj
Nov 06, 2010 | Garmin BlueChart g2 Vision Ireland...
I tranfert bluechart from my PC using mapsource to
I recommend upgrading your system software to the latest version (5.30),
follow this link for directions and the file's location.
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
  5. Load the SD card into your GPSMAP 545s and turn it on to replace the system software of your unit.
I hope that helps.
Jul 04, 2009 | Garmin GPSMAP 545s GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
I cannot access any of the maps I loaded onto my SD card
First of all, the maps must be created and match the serial number of the GPS you will run it on. Next the maps must be transferred to the SD card in the directory /MAP_DATA The GPS always looks at this directory for any map.
Apr 11, 2009 | Magellan Triton 1500 GPS Receiver
Installing national geographic topo maps on my magellan triton500
Two possible answers and they are both dependable on the serial number of the map vs.the serial number of the GPS. The best solution is to use Vantage Point to do the transfer. The second method is to directly load the map to an SD card under the directory MAP_DATA and then place in the GPS. Then do a MENU>>VIEW>>MAPS and activate the map. If the map is missing you do not have it under the MAP_DATA directory. If the map shows a RED "X" then the serial number of the map is not the same as the serial number of the GPS.
Mar 27, 2009 | Magellan Triton 500 Handheld GPS Receiver
Magellan triton 500 freezes up
You might have an sd card inserted that contains information that the unit doesn't recognize. This happened to me when I tried to fudge some old magellan destination maps onto the sd card...the format was wrong and the unit froze...gave me the message.
Mar 06, 2009 | Magellan Triton 500 Handheld GPS Receiver
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Magellan Triton 500 value bundle
magellan has a big problem in the past with the Canada Value Pack. It did not work with the Triton. It was only made to work with the older Magellan GPS units.
Best to contact Magellan and see if they will give you a new one.
Dec 29, 2008 | Magellan Triton 500 Handheld GPS Receiver
Have problems with the loading of the map XPC415S. Australia East coast. Will this map work with this unit?
Any bluechart that has been preloaded on an SD card should work.  Did you purchase your chip with the data preloaded or did you download it yourself?  If you downloaded it yourself, try erasing the sd card, format it, then insert the blank card in the 420 and power it up. This somehow preps the chip for the data download.  Then download the bluechart onto the chip and try again.  There is some ambiguous wording in the download screen that makes it look like some kind of error, try the download anyway and most of the time it will work. After the download is complete it should list the bluechart software version on the screen along with some other software info.  If the operating system software is not v2.5 or higher, you may need to download a software update first.
Oct 25, 2007 | Garmin GPSMAP 420s GPS Receiver
Garmin GPSMAP 76Cx GPS Receiver Logo
154 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
