Question about Fantom Drives 120 GB Hard Drive
SATA Hard Drive causing system to crash
I have had a Fantom 1TB external USB drive for close to a year now, and it has worked great until a week ago. It started having the problem I've read so much about now, where it will show up in the "Safely Remove Hardware" window but the computer will not assign it a drive letter. I tried several different computers running both Vista and XP, but the problem occurred on all of them. At this point, I decided to take the enclosure apart and remove the drive.
The drive is a WD 1TB SATA. I hooked it up to my Gateway's motherboard into one of the six available SATA ports. When I booted up the computer, it took me to the Intel Matrix screen. Here, it showed my original HDD was non-RAID and the HDD from the USB enclosure had had a SMART event. After some Googling, I realized this wasn't a good thing! When I booted after this, the computer hung up before Windows loaded. This happened on all the SATA ports, and I switched cables with the good one but the computer continued to hang. As soon as I disconnected the new drive, the computer would run normally.
At this point, I took the drive to the Geek Squad figuring it was toast but holding on to a glimmer of hope. The tech there took it in the back and hooked it up to their machine. To my surprise, he said it came up fine and healthy. He said he suspected the enclosure was bad and suggested I hook it up to the motherboard. I told him I had. He said he thinks my computer is trying to force it into a RAID configuration and that's what's making it hang up. He recommended changing the BIOS settings to prevent this.
I was happy that the data was still there, and came home in better spirits than when I left. However, after tweaking the BIOS settings six ways from Sunday, I am still having the same problem. Anything I change the BIOS Drie settings to (AHCI, IDE) will cause the system to crash. In the BIOS settings, both drives are shown and show the right size. I even tried something the Geek Squad tech recommended, which was booting up with the original drive, then adding the new SATA drive after Windows was running. Basically hot-swapping to the motherboard. As soon as I plugged in the SATA cable, the computer got a busy icon and hung up. When I disconnected the guilty drive and restarted, the system ran normally.
Does anyone know why this drive is causing my system to hang up? All my other computers are strictly IDE, so I can't check with a different system. The thing that blows my mind is that it came right up on the Best Buy system, but since I can't even access it there's no way to transfer the info and format the drive. Worst case scenario, I can get Best Buy to transfer all the data to another external HDD for $99, but I'd like to know if there's a way to salvage this drive.
Thanks in advance for your help.
  • 134 Answers
You can go to Western Digital's web site (wdc.com) and then go to their support section. In their support section you can download their diagnostic utilities. Note that you have to know the model number of your hard disk in order to select the right set of diagnostic utilities.
Also, note that some of the diagnostic utility functions are destructive in that they will erase all hard drive data. Follow their instructions about which diagnostic utilities you can run to check and attempt to repair the drive without losing all of your data.
Posted on Apr 21, 2009
2 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: unable to read data on drive
Hi Franoisebis,
I can help you with that, you will need a data recovery pro to attempt to retrieve your data. Unfortunately Geek Squad really isn't equipped to do that. If you reply with your Country, State and City I will direct you to an appropriate Pro nearest your location.
Chris
Posted on Aug 30, 2009
My 1TB Simpletech Simple Drive is no longer being recognized by my computer or my media player. My other hard drives pop up immediately and automatically when I connect them to my computer. Is the hard...
Is the hard drive making loud clicking? Try placing the drive in a freezer bag, and make certain you remove the air out. At that point, place the drive in your freezer for 48 hours. Remove, and see if you can get the drive to work- if so, great! pull all the files you can.
If it isn't clicking, sometimes you can remove the casing and connect the drive directly into your system- esp. if it is internally a sata drive. USB drive enclosures basically act as mini hard-drive controllers- ranging from a full adapter, to just passing info from a sata drive over USB. Mind, both of the actions I recommended would void the warranty if it is in warranty.
The final option, and the most expensive: Look up a data-recovery firm. Most are reputable and will not charge if they cannot recover anything- do your shopping before hand!
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Nov 13, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
Hard Drive not recognized by laptop
The Hard Drive could have come loose from the SATA or PATA connection, or your Hard Drive could have simply died. If it is still under warranty; replace it. If it is out of warranty; open the external casing and check that the HD is connected and / or test the HD in a separate external casing or Desktop that you have. If it is connected and the external casing is working properly (or Desktop is booting properly and can read it), then you have a dead Hard Drive and will have to buy a new one.
May 03, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
No connection to WD hard drive
just change the usb cord the problem is in the usb
Mar 05, 2010 | Western Digital My Book Essential 1TB...
Unrecognized FANTOM HDD volume
have you try it with another system? if no try it and if it continues then try scanning it with antivirus program installed in your system. if all this no success then get and another okay.
Nov 11, 2009 | Fantom Titanium Hard Drive
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Fantom 1TB external USB drive failure, only half seen by MAC
the operating system may be corrupting format the hard disk drive the notice its behaviour
May 21, 2008 | Computers & Internet
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Fantom Drives 120 GB Hard Drive Logo
301 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
