Question about GE WBSR3140DW Top Load Washer
HotPoint Top Loader model # WLW1500B
Washing Machine will not switch cycles. Will continue to run same cycle continuously. I found this out by accident when it stayed on the same cycle overnite. I can manually switch to next cyle, however, it will not move on to next cycle on it's own. I have never had a problem with this washing machine, if it is an easy economical fix would like to fix it. I have unplugged, turned knob thru complete cylce and replugged in several times, does not fix the problem. Anyone have any suggestions? Thanks.
  • 625 Answers
If you hear clicks then I'd have to say it was a mechanical timer. the timer has a small motor on it. a complete timer including its motor will run you about $120 but a replacement timer motor will be about $35.00
Posted on Sep 22, 2007
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
The washing machine starts ok and fills with water. However, it quickly begins to intermittently cut in and out whilst filling with water. It does this for a while before stopping completely. I've tried...
you did not mention the type of machine but for top loader the most probable cause of your issue is the door /lid switch that is in need of adjustment as most top loaders will fill with the lid open but cycle cant start or continue when the wash thinks the door is open this is a safety feature
Aug 14, 2010 | Washing Machines
How do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Jun 29, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How does a top loader work?
You lift the lid and load your washing into it. They you select the wash cycle, select the type of fabrics you're washing and the temperature and then start the wash cycle.
Then's all kinds of variation, but generally, there's a timer and a thermostat that control a lot of the cycle behaviour like washing times and water temperatur, if their outside the thermostat calibration, the washing machine may not continue to the next cycle until the calibrated temperature registers on the thermostat.
Was there anything else you wanted to know about top loaders?
May 10, 2009 | Samsung Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
585 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
