Question about ViewSonic VX2235wm LCD Monitor
I have a viewsonic 22'' (I think) model VX2235wm. It has both digital and analog connections in back. Can I use both -- one going to one PC, the other to a 2nd PC -- and switch between them?
  • 4,472 Answers
Yes you can. If you need further assistance on how to do it please let me know though its as simple as switching inputs with the buttons on the monitor.
Thank you,
Lee
Posted on Apr 21, 2009
I am using a Viewsonic VX2235WM monitor for photo editing
Hi!
Its actually normal. That normally happens to some monitor models at the 6500K setting. Try a higher one.
I hope this helps.
Jubert
May 18, 2010 | ViewSonic VX2235wm LCD Monitor
My VX2235 sometimes goes blank (black) for 2-3 seconds, then back on. This has happened thru 2 M/Bs and 3 Gr.Bds. Happens more on digital connection than on analog. Any ideas?
Common failure in this monitor is bad caps in the power supply or lamps, you need to open it up, post back what you see inside so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 25, 2010 | ViewSonic VX2235WM Monitor
Trying to pack
Few steps to take the stand and base off the 22" ViewSonic VX2235WM
1- Squeeze the bottom of the base to take the base off from the collar
2-This step is very important. The collar has two parts snapped in together, with 3 snap in each side. Carefully use small flat screw driver to take off the back side of collar
Feb 19, 2010 | ViewSonic VX2235WM Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
I cannot get desktop for internet Th screen say no signal analog. I only use it to surf the net the small light lights up
Are you using the DVI (DIGITAL) or the VGA (ANALOG) to connect to the PC? You may also have the caps that are going bad, see example here, you should check them out before too late.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 11, 2010 | ViewSonic VX2235wm LCD Monitor
I have a problems with my Viewsonic vx2235wm, the On/Off button does not always make a good connection in turning off the monitor. I will push it and it will go off and then come back on immediately. The...
press it several times very very quickly, if it doesn`t start functioning the front panel must be opened in a service and the contact cleaned...i don`t think it needs replacement
Oct 28, 2009 | ViewSonic VX2235wm LCD Monitor
Hi have a Viewsonic 22 VX2245wm. When it was
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 31, 2009 | ViewSonic VX2235wm LCD Monitor
Cannot get correct resolution
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Jun 04, 2008 | ViewSonic VX2235WM Monitor
No signal analog
Press the front screen button that has an arrow. It will be switching from analog to digital and digital to analog if you press it again.
Mar 12, 2008 | ViewSonic VX2235WM Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
208 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
