"The display control panel is unable to change display settings. You may not have appropriate administrator roghts to change this settings"
  • 433 Answers
Two thoughts...one...try and do it anyway...it just may be a nag and let you pass if you are the administrator.
second...who ever log on first is the administrator. Log off and Log back on in that position.
Another though- (three) if you have guest log on, turn it off on the control panel (USERS) and that may make the machine understand who the administrator is.
Hope this helps you my friend...good fortune
Posted on Apr 25, 2009
Monitor has blue hue, push the menu button window is correct though?
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size larger size or custom settings
always click APPLY after making any changes
also
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it
hope this helps you
Jul 23, 2011 | Computers & Internet
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
Fn key not works for brighness and sound
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
now for the soundif your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 30, 2011 | Computers & Internet
My aspire screen is upside down and the picutures are also upside down. How can I fix it?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
hope this helps
Apr 02, 2011 | Computers & Internet
My monetir ok pc low display
also
hope this helps
Mar 29, 2011 | Dell Optiplex GX280 (99301) Motherboard
Display resolution very low and bit rate is 4bit, unable to adjust both levels. also where can i obtain latest system disc for foxconn intel type motherboard.
also
hope this helps don
Mar 12, 2011 | Fujitsu Computers & Internet
Although display for width is visible 0 - 100 % but actual width is not changing
also
hope this helps
don
Feb 28, 2011 | Computers & Internet
Display problem
also
hope this helps
don
Feb 15, 2011 | Computers & Internet
Have a power but no display even the video card is good
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
If your computer came with a motherboard disc the drivers could be on it
also
hope this helps
don
Feb 14, 2011 | Computers & Internet
Monitor will rotate but the screen won't switch from horizontal to verticle position
control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or
hope this helps
Dec 11, 2010 | Computers & Internet
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
