Question about Garden
Is it possible to adjust the chain break & how to do it.
I have a Homelite 45cc chainsaw, model ut10942a , made August 2003. Is it possible to adjust the chain break. The only way it will totally release is if I pull the chain break release bar back toward the hand grip & hold it there. Right now I have it wired to the hand grip but I know that is not a safe proceedure but it works for now. Can you help. Thanks.
  • JSBIGPETE May 17, 2009
    Hello Steve & Josh,
    I thank you both for the Homelite chain break info.
    John
  • josh1111 May 11, 2010
    yea sounds like something is broke on the brake handle gears could need a replacement handle.
  • 181 Answers
Hate to say this,but,there is no way to adjust the tension on the brake band.either the spring is weak or the brake band is broken.either can be changed but it's not easy.spring is under a lot of tension and can fly out when taking it apart or installing,you can get the entire cover as a unit if so desired...hope this helps,let me know
Posted on May 13, 2009
I have the same saw and the same thing just happened with it.
I removed the chain brake handle and found that a flat spring steel part had one end broke off.
Its not the brake band but another spring.
I found the part # online (PS04955) but still have to find one and see where the broken missing end fits in the brake.Hope this helps.If you like I could send a parts list showing the part.
Posted on Jul 06, 2009
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Need replacement part
Google Homelite PN# 310508001 and you will find it at many locations
May 09, 2013 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Manual for 330 homolite chainsaw
losen the nuts for the clutch cover and tighten the screw on the side of the bar
Mar 23, 2012 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
I need a manual for a Homelite chainsaw Where is
Hi calwolfe...
Go to the following website and download your manual, if it is among the list.
You did not get me a model so I did not have much to work with to find your user manual for your chainsaw.
Please take time to rate me
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Sep 10, 2011 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Unit runs great. I beleive I am getting too much bar oil from the chainsaw. There is bar oil dripping from under the cover where the bar connects to the unit. Is there an adjustment for this? I have...
There is no control on how much oil is sent to the chain.
You should be using about a tank of oil to a tank of Gas
Things to check Are you using Chain and bar oil or regular oil
Chain and bar oil is thicker and has additives to make the oil stickier. regular oil is thinner and tends to run out of the saw when you are not using it.
If you are using correct oil and using to much sounds like the oil pump needs to be replaced
Jun 27, 2011 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
I have a Homelite Chainsaw 45cc Power Stroke. Model No. UT10946D. The chain brake is always applied. Brake lever will not latch in the released position. I've disassembled it and do not see anything...
I have the same model (ut10946d) and used it for less than 2 tanks of gas when the chain froze. I noticed it was slowing down and it seemed like the chain brake was not disengaging and staying in the "unlocked" position.
I took the tool apart today and found that the band that rubs on the clutch to stop the chain was dragging on the clutch because it doesn't disengage all the way. The heat from the friction melted the plastic parts around the clutch housing and crankshaft. So now I have a chainsaw that I bought new, used for less than an hour, and is now junk due to poor design and/or product control.
I WILL NEVER BUY ANOTHER HOMELITE GAS POWERED TOOL AS LONG AS I LIVE. THEY ARE PURE JUNK!
My solution, call homelite and complain about it, maybe they'll stand behind their design flaws - but I doubt it.
Jun 18, 2010 | Garden
Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Aug 29, 2009 | Garden
No start
Possible ;Not likely. I would see if the woodrift key on the flywheel is partly sheared.
Jan 16, 2009 | Garden
Garden Logo
415 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
