Vizio 22 inch HDTV--Loss of volume on non-HD channels only
I have a new 22 inch Visio HDTV connected directly to regular analog cable, no converter box. It was fine for about a month but all of a sudden, I get drastically reduced/non-existent sound ONLY on the channels that are not HD. At the same time, the channel descriptions for the non-HD channels got all wacky. All channels that come up as HD are fine. HDMI DVD player is fine. Watching through DirecTV converter is fine,k even though channel 3 that it broadcasts on is virtually silent until I turn the sat box on. Suggestions? Did I hit some setting that is squelching non-HD programming?
    President:
  • 1,779 Answers
Good evening! Go into your audio section of the Menu and make sure that SAP is off.....let me know how you did.
Posted on Apr 21, 2009
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
JUST BOUGHT UNIT AND ON HD CHANNEL VOLUME SEEMS TO DECREASE AS U WATCH IT. SEEMS OK ON REGULAR NON HD CHANNELS ANY IDEAS???
this could be 1 of 2 problems, your cable/sat box or just a setting on the receiver. I would check with you provider.
Jan 15, 2011 | Vizio L32 32 in. LCD HDTV
My 32" Vizio when not on a HD channel has a
could possibly be a Line noise issue from your cable provider, if it's an analog signal. I would try another room in the house to see if your problem goes away. If not, it may be something your cable company may have to look into. This may also be associated with intermittent connectivity if you have cable internet as well.
Dec 08, 2010 | Vizio L32 32 in. LCD HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
328 people viewed this question
Top Televison & Video Experts
