Question about Sony Mavica MVC-FD85 Digital Camera
The camera is not charging
The light does not come on when I am charging the camera. Nothing happen. Do I need another AC adapto?
0 characters
1 Points
No signal from Sony security camera
test the adapto for open or faulty.
2( test the batteries for faulty, not charging, or band contacts clean it, or repair power supply inside the camera.
Otherwise you must go the repair shop for fix it.
God bless you
Sep 22, 2012 | Sony Digital Cameras
Nikon Coolpix: can't charge battery
Charge up the battery. Most digital cameras use a lithium battery and the battery needs to be removed from the camera and inserted into a charge adapter to be charged.
May 31, 2012 | Nikon COOLPIX L20 Digital Camera
When i plugged it in for the first time to recharge battery, nothing happens - no flashing green light - I left it plugged in anyway but it still did not charge Coolpix S3000 EN-EL10 Li-ion battery...
I faced the same problem too. But I realised that after plugging in the adapter and connecting it to the camera, you would need to press the power button but not turn it on.
Apr 14, 2010 | Nikon Coolpix S3000 Digital Camera
My camera cannot turn on or off is only 3 months old tried what might be the problem? i tried to charge the battery nothing happened i tried to take the battery out and back on still it did not work. i...
1. Remove the batteries from the camera and the memory card
2. Batteries should be Li-Ion Rechargeable Digital Camera Battery KLIC-7001 3. Verify batteries are inserted correctly
4. Place the camera in Auto Mode (Its green camera icon on the dialing mode)
5. Turn on the camera (if it failed try charging the camera)
6. Plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
a. If lights on battery charging light [solid green]
>charge the camera until light turns off or (up to 3hours)
b. If lights on battery charging light [red or flashing red]
>camera batteries are weak; replace with recommended batteries
c. If lights on battery charging light has [NO light]
>Try new set of supported batteries to test the camera one last time
>If already tested with a new set of batteries, set up the camera for repair
8. After all the step still camera will not work contact Kodak support line at 1 800 235 6325 (23KODAK) ** since the camera is less than a year it can be sent for repair in warranty. To receive warranty entitlement, you need to include a photocopy of the receipt or proof of purchase
NOTE: If Kodak repair center finds out customer induce damage, you will pay for the repair cost
Nov 19, 2009 | Kodak EASYSHARE M1063 Digital Camera
The camera doesn't turn on at all. Tried new duracells and freshly charged rechargables. The green light comes on whilst the switch is held down but nothing happens, nothing on the screen and the lens...
Hello. Begin by cleaning all of the terminals in the camera and all of the battery terminals with the eraser end of a common pencil. you may merely have a thin coating of corrosioin preventing you from getting a good connection and also a good recharge.
If that does not fix it, try these steps:
f your camera will not turn on, do the following:
  1. Remove all sources of power (batteries and AC Adapter) from the camera.
  2. Remove the Picture Card.
  3. Wait a full minute.
  4. Press the Power button twice.
  5. Connect the appropriate AC Adapter to the camera.
Nov 14, 2009 | Samsung Digimax S630 Digital Camera
Panasonic DMC-TZ5 will not turn on
I had a similar experience, both with my original TZ5 and the replacement TZ5 Panasonic sent me. I was mystified at first, but now I think it's the AC adapter I was using. With the replacement camera, absolutely nothing happened between taking pictures of my new house and plugging in the camera to export the photos. The back of the camera near the AC input got really hot and my surge protector shut off. The camera won't turn on. I don't know about warranties, but if you think that's the problem and were using a Panasonic AC adapter, you should check. My (non-Panasonic) adapter worked ok the first time or two I used it.
Jun 15, 2009 | Panasonic DMC-TZ5 Digital Camera
Fuji F650 camera 1yr old. Worked great till the other day I went to turn it on the green light came on but nothing else happened. I recharged the battery but it still does not work. The green light will...
the battery is not holding charge anylonger.need to buy new one (aprox $9 on ebay) or try to have it rplaced atthe store you bought the camera from (it should last more than 1 year for sure)
Oct 02, 2008 | Digital Cameras
Lights!Camera! No Action!
do you have a memory card installed?
is this camera new?
not seeing in the viewfinder is not a good sign.
if its a slr, the mirror is locked up, either by function or failure.
need to know if its a slr or small format point and shoot to offer further advice.
Dec 21, 2007 | Canon PowerShot S3 IS Digital Camera
Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Aug 24, 2007 | Casio Exilim EX-S500 Digital Camera
Sony Mavica MVC-FD85 Digital Camera Logo
26 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
