Question about Coby MP550 MP3 Player
I formatted my mp3 player. The software there inside it also deleted. So it is not charging now
    Master:
  • 505 Answers
You can try downloading a data recovery program and you just may be able to get the software back try easy recovery
Posted on Jul 23, 2009
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
How can i delete all music from my mp3 rca series 10
Check to see if you can format it through the menus inside the mp3 player.
It might be in "Settings" or "Tools"
There will be an option called Format
Select and it "should" delete all music
If there is no Format on mp3 player
Plug it into the computer
Open device through "My Computer" or "Computer"
Select Folder where music is stored and delete.
Sep 24, 2009 | RCA S1000 MP3 Player
Database full, delete content or re-format device
you should format your mp3 and try again.in this way the errors on mp3 player will be removed.
Jun 01, 2009 | Insignia NS-DV2G MP3 Player
WANT TO DELETE
format everything. Use software and manual to help u. or just delete everything manuly useing the software they sent you.
Feb 01, 2009 | Nextar MA566 MP3 Player
My JNC SSF M9 20GB MP3 player not working
Hi, I´ve got this JNC SSF-M9 MP3 Player 20GB since years, but now I lost my AC Adaptor. The Its a Toshiba Harddisk inside 1.8" MK2004GAL 500mA, 3.3C and the accu is 3.7V with 1300mA. So does anybody know, which Adapter (voltage and current) Ineed for this? Please help...
Thanx Christian
Nov 14, 2008 | JNC Computers SSF-310 MP3 Player
Prblem
Any body have the solution for this,I made format x-micro but it software deleted.
Aug 15, 2008 | X-Micro Technology EVA MP3 Player
Deleting music from mp3 player
do u have Tronic firmware for mp3/wma/fm/rec ?
Aug 12, 2008 | SanDisk Sansa m230 MP3 Player
I cant format my mp3 player
Did you try formatting it from software or the process through My Computer. If you used software process try this other way below.
To format your device first click on "Start" then click on "My Computer" now look for your mp3 player, if it hasn't been change the names usually called "Removable Disk", once you've found that right-click on it then click on "Format".
Good luck. Hope my solution was helpful.
Oct 26, 2007 | Creative Labs Muvo V100 MP3 Player
I cant access the files on my Sansa from my pc
You may need some sort of proprietary software to 'see' the portion of the drive with your music. It might also be that the drive is formatted ina format not compatible with the operating system you are using. What OS are you using? Have you put music on the player in the past?
Jun 19, 2007 | SanDisk Sansa m240 MP3 Player
Won't format and won't play mp3
try loading files on different bit rates and see what bitrate your player can play. some player wont play files that are directly copied to the player, it needs a certain software to encode it to its standard format. sony walkman is an example, it has its own software to encode files from mp3 to its own supported format.
May 17, 2007 | Creative Labs MuVo S200 MP3 Player
Coby MP550 MP3 Player Logo
260 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
