Error code on Enigma SLR-35 air conditioner. The error code is L1, air con will come on for a minute or two and then shut down displaying this error code. I don't have the manual for this air conditioner as it was in a house I just purchased and was just wondering if anyone knows what this error code means before I call in a repairman to investigate. I have tried cleaning the filters and resetting my circuit breakers for the house. No success obviously. The air that does come out for the minute or two feels cool like the air con is working. There is what I suspect is a reset button/self test button on the front of the unit which I hold down when powering up and it goes through a bunch of light flashes and beeps but then pops back up with L1 on the lcd display. Cheers for any help anyone can provide.
justaplumber
  • 98 Answers
SOURCE: Electrolux air conditioner
Tell me the model no. and I will find info or a new manual for you.
Without this info I cannot help you as there are many different coolers made by electrolux.
Posted on Dec 23, 2007
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
SOURCE: Haier Air conditioner does not turn on
I was having problems with my Haier A/C staying on, also. My timer was even changing on me. I just purchased it a few days ago, and the instructions were no help. My son decided to play video games on my Toshiba TV and change the brightness, (low and behold), this turned my A/C on and off. Then we found out the volume on the remote to the TV changed the timer on the A/C. We now have a peace of tape over the sensor on the A/C and it works fine now.
Posted on Aug 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
SOURCE: Everstar portable AC not cooling, what do I do?
Same thing happened a few weeks ago. My wife said " its not cooling". I read the manual and it says., Clean filters ...we did and hello. works fine. She was so frustrated she was going to take it back. These filters accummulate dust fast. So check there first. Hope this helps.
I would lkike to know where to get replacement filters or an extension exhaust duct.
Posted on Sep 06, 2009
What does error code L1 mean on my chigo air conditioner unit
When posting hardware questions, it is useful to post brand and model number. There are a number of Chigo air conditioners. I have examined an error code page for the brand and the error L1 is not listed. However, on page 25 of the following manual, L1 is identified as a current transformator of which there can be a No-voltage for over-c
urrent detection circuit. See 4) Electric control panel detection sub-number 3 on that page.
http://www.investliving.se/upload/images/Produkter/Luft-Luft/New%20Basic/Service%20Manual%20New%20Basic.pdf
Dec 18, 2017 | Heating & Cooling
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Air-Con Mini split --gives error code 4 shuts down after 25 minutes
Hi Emanuel,
Your out door unit could be very dirty or the outdoor unit temperature sensor is out of position.
May 04, 2014 | LG LS-K1830CL Cool Mini Split Air...
What is an error 3 in conia split system
shut down the energy alimentation for 2 minute ,but if the defect persist error it show again
Dec 13, 2013 | Heating & Cooling
Air conditioner keeps turning off
Never heard of that brand. These appliances are designed to shut down and protect themselves when there are certain problems. High head (discharge) pressure (dirty or obstructed condenser coils) or low refrigerant (Freon) charge (leak anywhere in the sealed system) will cause the unit to shut down. Look to make sure that the unit's discharge is clear (not obstructed), and that the warm (condenser) coil is clean.
Dec 01, 2013 | Heating & Cooling
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
309 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
