Question about Dryers
Ignitor glows red hot,but no flame.problem is intermittent
Gas dryer,no heat.model 11072852100
  • 4,655 Answers
Most times that's an indicator that the gas solenoids are not working or th heat sensor . But I believe you need to change the 2 gas solenoids. If you need my help finding the parts for you let me know, Thanks, Sea Breeze
Posted on Apr 21, 2009
I have a gas dryer and cloths come out wet
Does the dryer get hot? If so check dryer vent.
If it is cold check the gas supply. Next open the lower cover and look to see a red glowing from the ignitor when running. It it comes on and no flame then you probably have a bad gas solenoid. If there is no red glow then it is probably the ignitor.
Hope that helps
Dale
Nov 10, 2013 | KitchenAid Clothes Dryer Gas Dryer Ignitor...
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Dryer runs....no heat
Make sure the lint filter and the exhaust vent pipe are not clogged.
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 21, 2009 | Refrigerators
KELVINATOR GAS DRYER. IGNITORLIGHTS UP THEN TURNS OFF. NO HEAT.
the ignitor needs to be glowing white hot not orange. it is not hot enough to ignite so you need to replace it.
Oct 04, 2009 | Frigidaire FGQ1442ES Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Dryer Model DE306 has stopped heating
Aug 13, 2009 | Dryers
Dryer won't get hot
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Dryers Logo
242 people viewed this question
Top Dryers Experts
