Question about Canon 3045 Black and White Copier
"Clean Glass" message
Okay, I guess I wasn't clear. I want to completely disable the message. I don't want this feature on my machine. Is there: A. A software tweak to disable glass checking. or B. A sensor that I can unplug to disable this annoying feature. << How do I disable the error message telling me to clean the glass? No matter how often I clean it I keep getting the message, and I cannot proceed with my copying until I click the message. >>
    Problem Solver:
  • 18 Answers
Service mode setting required,call service agent.
Posted on Oct 15, 2007
  • 31 Answers
So far I've been unable to find how to disable the message but I know it can be done. Until I find how to disable message I would recommend this- there is a white piece of mylar located underneith the top frame that the scanner uses to get a white level reading during warm up. The glass must be removed in order for you to access the white mylar. Remove the glass & look underneith on the left hand side- you should see the mylar stuck to the top of the frame. You may need to slide the scanner to the right to give yourself enough room to clean it. Obviously do this with the machine off & unplugged. If you want to send me your email address I'll send you the disable instructions as soon as I find them. Please put 3045 clean glass in subject line in case it gets dumped into my junk email.My email is [email protected]
Posted on Sep 21, 2007
SOURCE:
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
WW2277HW
My guess is replace the drain pump. Inexpensive part but kinda hard to get to. Check out repair videos on parts sites or YouTube
Jan 30, 2018 | LG WM-2277HW Front Load Washer
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
My nokia e72 shows a message select WLAN network,i don't know what shoyld i do,it doesn't accept any adressess,and i can't use it.plz help ur solution wasn;t useful 4me
pari_mch2007,
select Menu > Tools > Settings > Connection > Wireless LAN
you can disable the search function there
let me know if you need further help
Aug 22, 2011 | Nokia E72 Smartphone
My Bernina 730 has a message (Check hook System). Do I need to take in in for service? Can I continue to use it?
Don't be dictated to by computerized machine, as long as you keep the raceway clean and a few drops of oil and it sews okay then you will be okay
Aug 07, 2011 | Bernina Artista 180
How do you fix a ventilation problem
Ventilate means water is not moving through the machine or the machine is not noticing the movement of water.
Try to use the water button to clear the ventilate message. Allow the water to run for a minute. If no water comes out then the hot water valve is stuck and cannot open until you open the valve manually and clean it well. If you don't think you can complete the repairs yourself, then you may want to bring to a service center. Descaling with a descaler like http://www.cerinicoffee.com/Saeco_Espresso_machine_descaler.asp will help prevent these issues.
Jun 07, 2011 | Saeco Royal Professional Espresso Machine
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
The scanning feature doesn't work
Make sure once you have the software installed properly that you set up the file ( address) correctly. You need to have the designation specified.
Dec 30, 2008 | Canon ImageRunner 2220I Copier
"Clean the glass" message
This is a service mode setting that needs adjusting. Refarance the dust level detection Contact service agent.
Sep 19, 2007 | Canon 3045 Black and White Copier
Canon 3045 Black and White Copier Logo
80 people viewed this question
Clive
Clive
old marine
old marine
Ekse
