SOURCE: Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
SOURCE: Sansui Projection TV - RCA
CK for Bad capacitors cp114,120,150 if any of them is puffed up on top it is bad so replace all 3 cp150 is 2200uf 16v other two are 220uf 35v also resolder all pinns on FBT flyback transfomer.
SOURCE: big screen tv comes on with great picture and then
The blue CRT or the Blue CRT drive board needs replacement. You can get the parts at www.tvrepairworld.com
