Question about RCA D61W20 61" Rear Projection Television
RCA ITC222 Board
I have a RCA TV with the ITC222 board. The problem was when you turn it on it makes a sound like a mouse is getting shocked. I replaced the 0087uf 2000Vdc cap, It was arcing so bad that it burnt a hole in the board. I also replaced the cp114 cap that had a puffed up top. It still continues to do the same thing three times when you turn it on. Please help as the wife wont let me get a new TV. Thanks
  • hkowacz Apr 24, 2009
    Ok, So I replaced CP150, CP114, 0087uf 2000Vdc cap, CP120. And checke the 1.25amp fuse and it was good. The set still does the same noise like its shocking a mouse. What else would cause this. Thanks Heath
    President:
  • RCA Master
  • 1,779 Answers
Also replace CP150 and CP120 then check for an open 1.25 amp fuse. It looks like a little tiny brown box behind the composite inputs about an inch inward. We always change those caps regardless of the problem. GO GET EM TIGER. Let me know?
Posted on Apr 21, 2009
I turn on the tv for 5 sec its goes off and wont come on
Thats almost always caused by the deflection board you can get a replacement deflection board from the following link you would need the ITC222 deflection board http://tvrepairworld.com/rca_crt_projection_tvcircuit_boards/rca_rear_projection_tv_deflection_power_boards
Feb 03, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv will not turn on. RCA 52" rear projection. Green light comes on but no picture then green light turns off.
That sounds like the ITC222 chassis HDTV with a bad deflection board. But will need the full model number of the set to assist with the problem.
Aug 09, 2011 | Televison & Video
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Hi pitch sound (possible feedback) is emitting from tv. I have unhooked all sources into the tv, sound is still there. How can I fix this problem?
Replace the deflection board. You can get replacement ITC222 deflection boards from www.tvrepairworld.com . They also include the instructions on how to remove and replace the circuit board. They are listed under the RCA circuit board catagory.
Jan 14, 2010 | RCA D52W19 52" Rear Projection Television
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound went out on my RCA D52W20 rear projection HDTV while watching it.
ok sound on the rca itc222 chasis comes ofd one curcit board. This board is called the small signal board. but before we get this replaced we have to elemate a few things. one check you audio setings and make sure the amplifer is set to internal. also you speakers could have blown. and the connectors to speaker unlikely be loose. If these items are elemanted then the small signal board. a item that only technicians can replace. they have special computer interface they use to download data from the old to a new board when they replace it
Dec 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My TV turns off then turns it self back on 3-5 minutes later. We are told it is the small signal board?
rca? d61w130 itc222 ..does the unit flash green led.
itc222 shut down if the processor detects a problem. can be many different things. horizontal output is first thing to check. any sounds, chirps, smell... did it ever work
Dec 19, 2007 | RCA D61W130 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
230 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
