This work computer's monitor is too bright while working in low-light environs. Does it have a brightness control that I'm not seeing?
My monitor is too bright on my acer aspire. Does it have a brightness control?
  • 221 Answers
You can adjust the LCD brightness by pressing the Fn key at the bottom left of the key board, and then press the left and right arrow key's at the bottom right of the key board.
Posted on Apr 21, 2009
This is very easy and it worked. Try it now and see for yourself .
Posted on Feb 28, 2010
E196FP monitor brightness controls do not work
It an happen due to moisture, Temp solution unplug the cables and take it near a light to just give a mild heat and then reconnect.
Feb 19, 2010 | Dell E196FP 19" LCD Monitor
Hanns-G HW191D LCD - Image there, just not bright! Monitor looks black
There is a flourescent light that backlights the screen. If your screen brightness control will not make the screen any brighter, then the backlight has stopped working. You will either have to replace that light or replace the monitor.
Jul 11, 2009 | Hannspree HW191D LCD Monitor
Adjusting Brightness on LG Flatorn Monitor
You cannot adjust the brightness with the key board. If the brightness control on the monitor is not working. It may due the defect of screen control on the flyback transformer. You have to replace the flyback transformer (FBT)
May 23, 2009 | LG Flatron F700P 17" CRT Monitor
Brightness
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Nov 21, 2008 | Hansol 500 A Monitor
Computer Monitor Problem or anything else
Contrast and brightness controls usually come from one chip. You can try looking up the specs of the chip online and then determine which pin of the chip conrols brightness. Usually faulty Electrolytic capacitors act like the simptoms you described. Find the Electrolytic capacitor connect in the brightness circuit and you will most likly fix your problem. The chip that contols the brightness might also be faulty. Good luck.
NSSMS
Jul 21, 2008 | Compaq CV 7500 17" CRT Monitor
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Screen goes black
I recently had a similar problem with a MAG LCD monitor. Try the following to see if this resolves your problem: - set brightness to a lower level. On LCD monitors you can go as low as 0 and still see the screen. With my problem when I set the brightness below 70% the problem went away. A few days later I turned it all the way up to 100% and the problem did not return. However I did not continue to keep it at that level. I found no need for it and find 50% to be exceptable for my needs. I would say yes it does have something to do with the lamp controler which controls the lamp brightness. I do not know all the technical reasons why a controler starts to have this sort of problem. If your monitor is still under warranty I would take advantage of the free repair otherwise keep the brightness below the level that causes the problem; for me that was under 70 percent. I hope this solution works for you. Perhaps there are others that can give you all the technical reasons why a controler starts to exhibit this behavior. Sincerely, Dean Kenneth Robinson
Aug 14, 2006 | LG Flatron F700P 17" CRT Monitor
Green light and screen flash then go blank every 3-5 seconds and nothing else
heat from the switch mode power supply in the unit will detierorate the 1000mfd/16volt caps.I replaced all 4 of mine to restore from a dead unit
Aug 14, 2006 | Compaq FP 7317 17" LCD Monitor
Computers & Internet Logo
582 people viewed this question
David Payne
David Payne
