Question about RCA 32F531T 32" TV
Model F27650 RCA Entertainment Series
I have the same problem green light blinks and sounds like its comimg on the does nothing
  • 2 more comments
  • zirks80 Apr 22, 2009
    I left the tv unplugged fro 24hrs. and when i plugged it back in it started to make an ear piercing sound that just keep going. I even unplugged it and plugged back in and it continued.
    Also dont know where the reset is at?
    Thanks
    Thanks for trying to help. nothing comes on the screen at all. I was trying some solutions and after being unplugged for 24hrs the tv just makes a loud high pitch noise.
    Yes, it sounded like it was starting to power up then would stop and do nothing. Now it is just a very high pitch noise when i plug in. i dont even turn it on.
  • zirks80 Apr 23, 2009
    OK thanks for the info was hoping not that bad but it is what it is.
    Thanks again
  • RCA Master
  • 3,866 Answers
The PSU power supply unit needs to be replaced what your hearing is the capcitors go and when they go you will not get anything after that. there may be power to the mainboard but it will not let it go to the screen for safety reasons. Solution is to take it to a qualified repair shop.
Posted on Apr 23, 2009
    President:
  • 1,223 Answers
No picture, no sound but TV is on
is that the case
Posted on Apr 22, 2009
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais Apr 22, 2009
    do u see menu on tv if u try to go to menu using ur remote control then try this
    Depending on your model, pressing CANCEL or RESET on the remote, or
    selecting Reset on the menu while making picture adjustments, will
    return all adjustments to factory preset levels.
  • Shoaib Rais
    pls also try to reset ur TV like this
    Make sure the TV is off. Simultaneously press and hold VOL< on the TV’s front panel and CLEAR on the remote for approximately 5 seconds
    and see if it works otherwise
    tell me
    what happens if u connect DVD player ?
    What happens if u take ot all conn leads what u see on screen ?
    more detail abt the malfunc
  • Shoaib Rais
    kindly reply with results in order to get ur problem solved or if it is solved then also confirm by reply
    Brigadier General:
  • 3,614 Answers
Try the following troubleshooting steps.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Posted on Apr 21, 2009
  • micromaster
    micromaster Apr 22, 2009
    sorry for late reply, as i have examine on your post it seem that i already stated it to you this.
    either of this has failed & need to be check & replace. doing this you may need someone to help you. so i will advise that you need to call a repairman to help you.
My rca hdtv r52wh74 the green light comes on and off 3 times and nothing else no picture or sound just goes off
Thats a deflection issue. You can get the ITC222A deflection board Bar code PSB-260 from www.tvrepairworld.com which will usually fix the 3 blink error on that model
Sep 24, 2011 | RCA Televison & Video
Rca model number d56w20 green light blinks 3 times and then off , repeats cycle 3 times then nothing. no pic no sound
Sorry but I can't afford your service, and yes i stil have the same prob..
thanks
jandjmayo@yahoo.com
May 29, 2009 | RCA Televison & Video
Instruction manual for RCA F27665
here is the link for the User Manual for the RCA F27655 Entertainment Series PIP
http://support.radioshack.com/support_video/54161.htm
Jan 13, 2009 | RCA F27665 27" TV
RCA F27650 32" TV Problem
Hello ddw7321,
This sounds like it could be a malfunction in the High Voltage section of the TV. The shutdown circuit is switching on and preventing the TV from turning on. This might be due to an excessive amount of current flow possibly caused by a shorted turn in the Integrated High Voltage Transformer (IHVT), or a shorted Horizontal Output Transistor (HOT). To test this you will have to unplug the TV set, and with a multimeter set to resistance, measure the resistance from the collector of the HOT to ground, If it reads 0 ohms then that is the problem (a shorted HOT). The next test which is of the IHVT is a little difficult because it requires removing the IHVT and doing a ring test. At this point I would like to suggest that you take the TV to a repair shop, because these next test might be difficult for someone who does not know electronics, and if you have no knowledge of electronics you may do more damage then good.
With that being said:
Remove the HV anode of the IHVT connected to the CRT by first using a large flathead screwdriver connected with a clip lead to the ground of the TV, by sliding the screwdriver under the rubber cap and releasing the clips. Then unsolder the pins on the bottom of the IHVT using a soldering iron and a suction type desoldering pump. when the solder is removed , pull the IHVT from the circuit board. locating the main primary winding connect it to the device that you are using to perform your ring test (I use a Sencore LC-102), when it is connected do the ring test and it should have at least 10 rings to be considered good, any less then 10 and the IHVT is to be considered as bad.
I hope this helps.
Thank you,
Shuttle83
Oct 04, 2008 | RCA F27650 27" TV
RCA entertainment series 42 in will not come on but power light blinks on & off.
I will need the model number of your RCA and also how many times the led blinks. Please respond to this same post when replying
Jul 31, 2008 | Televison & Video
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
SBlinking green light
Have you tried disconnecting the power from the wall? Or power cycling your entire entertainment center? Possibly even check to make sure the VGA cable (or any other cable) didn't somehow come looose?
Jan 21, 2008 | Insignia LCDTV26 26 in. Television
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
RCA 32F531T 32" TV Logo
201 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
