Question about E-Machines eMachines Desktop PC
To restore to origionalfactory settings
E-mashines-3230 hello ,i amtrying to restore this mashine to origional factory settings, i keep getting register errors, also i cant get it to copy dvd
    Problem Solver:
  • 11 Answers
Are you getting registration errors or are you getting registry errors . If you are getting registration errors then you can call up the microsoft activation helpline and they would guide you through the registration process. if you are talking about registry errors then its something about the hard drive being faulty. so try to do a format reinstall. If you need more detailed help. write back. Thanks Ashish.
Posted on Sep 22, 2007
How i can to reset Blomberg dishwasher
first thing to do is unplug for 3 minutes plug back in. Reset?
restore the factor settings:
Enter into the "Settings Menu"
(Press Function and Time Delay
Buttons together for 3 seconds)
When the Main Menu is displayed,
keep the Function Button pressed
until "Restore Factory Settings? is
Factory Settings menu do not
have any submenus and it is
enough to press "Confirmation
Button" to reset the settings.
Exit the menu after "** Stored! **"
is displayed
hope this helps.
Jan 07, 2018 | Blomberg Washing Machines
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
Mar 24, 2015 | Washing Machines
Saeco xelsis leaking water
The removable drip tray inside the front of the machine has two rubber inserts on the back side and the rubber has come away from the plastic causing a false leak. You will need to order a new one or fix the existing one.
Nov 26, 2013 | Coffee Makers & Espresso Machines
Sewwing mashine sudenlly just turned off
if you have tried unplugging and letting it set for a few mins and plugging it back in... and still have no joy... it is likely that a short or something blew a fuse. I would take the machine in and have them do a check, clean and adjust while they did the repair.
Jan 14, 2013 | Sewing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
Thread comes out of needel and into gears
are you threading the needle from the front of the machine to the back ?? that will help as itwill not sew at all the other way , just a thought
Feb 18, 2009 | Sewing Machines
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
E-Machines eMachines Desktop PC Logo
143 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
