Question about Gemini XL-500 Turntable
Cant get my turntables turned on and there connected to my mixer do i need the power cords for the turntables????
If there is a slot for a power cord on the turntables them selves then yes you need the power cords
Posted on Apr 22, 2009
My technics 1200 hums when connected to the amp even when the power cord is disconnected.
Is the ground wire from the deck connected to the mixer?.
If everything is connected ok then the ground wire or phono cord could be faulty - look here for replacements :-
http://stores.ebay.co.uk/methleykev
Could also be a "ground loop" - try a ground loop isolator.
Jun 26, 2010 | Technics SL-1200 Turntable
I received the turntables and mixer but Im having trouble installing everything together. Is there any companies that can help you install the turntables, mixer, and speakers
Not to worry if you can take some pains and be confident. First of all arrange the turntable, the mixer, the amplifiers and the speakers. Connect the turntables two RCA pins to the PHONE pins L and R. of the mixer. Using another set of RCA cables to connect the output of the mixer to the amplifier's AUX inout L and R. Try to connect the red and white in accordance to the L&R. The speakers should be cconnected to the left and right of the amplifier's main. if you have front and rear use them but connect with the polarity of the red and black polarity . Use a good power supply multipin unit to connect all the power. Do not switch on until you have checked once again. Now switch on and play your favourite record. DO take time to do and you will suceed. Good day
Jul 11, 2010 | Stanton ST-150 Turntable
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
My power cord was pulled out while still on.
Are you talking about a Numark DXM mixer? If so, why would you say you have an issue with a CDJ-800? Numark Parts can be found here.
If not, you need to be more specific as to who makes your mixer.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 10, 2009 | Pioneer CDJ-800 Turntable
How do I connect CDJ 800 to work on mixer AND surround speakers?
you did not mention that you have a power amplifier to drive your Speakers. well you need to have one unless you have a powered speaker. the sugnal comes from the mixer main output goes to the input of your amp. or powered speaker.
Feb 03, 2009 | Pioneer CDJ-800 Turntable
Plugged cdj-800 and mixer into a European outlet-now they won't turn on
ok, remove screw under the cd mixer and slide down carefully the top of the cdj and then trace where the power cord connects in to circuit(there is a fuse there try to change anew one..thats is!
Aug 11, 2008 | Pioneer CDJ-800 Turntable
Humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
Feb 19, 2008 | Stanton STR8-150 Turntable
Have a B&O RX-2 with mcc4 and loud hum
Possibly check the wires on the cartridge, make sure none of them are touching and are not bent to badly, are all the connections tight? some cartridges require plastic sleeves over the connections, this insure they don't touch and
avoids resistances between them. Also some cartridges are not compatible with certain model turn tables.Is it universal? Also you my need a mixer most turntables don't work with amps alone. Mine don't. Usually most models you attach the ground wire to the mixer. A mixer boosts table power and take stress off the amp. Hope this helped! good luck!
Jan 31, 2008 | Sony PS-LX350H Turntable
Gemini XL-500 Turntable Logo
119 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
