Question about Canonical Ltd. Ubuntu
Ubuntu 8.04 Sound is Very Distorted HELP!!!
Every sound that comes out of my speakers sounds horrible!!
how do i fix this??
  • jaymcelroy21 Apr 21, 2009
    the sound still does not work
    Problem Solver:
  • 11 Answers
You need to add the following lines to /etc/apt/sources.list file or you need to make sure you have enabled Universe and multiverse repositories in /etc/apt/sources.list file
sudo gedit /etc/apt/sources.list
Make sure you have the following two lines save and exit your file
deb http://archive.ubuntu.com/ubuntu hardy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu hardy universe multiverse
Now you need to run the following command to update the source list
sudo apt-get update
Install mplayer using the following command
sudo apt-get install mplayer
if you want to open mplayer just type
gmplayer
or
You can Open from Applications—>Sound&Video—> Mplayer Movie Player
Install libdvdcss2 and w32 video codecs in Ubuntu 8.04 (Hardy Heron)
Support for WMV, RealMedia and other formats has been bundled into the w32codecs package. This package is not available from the Ubuntu repositories due to licensing and legal restrictions.
For Ubuntu 8.04 (Hardy Heron) Users run the following command
sudo wget http://www.medibuntu.org/sources.list.d/hardy.list -O /etc/apt/sources.list.d/medibuntu.list
Then, add the GPG Key using the following commands
sudo apt-get update
sudo apt-get install medibuntu-keyring
sudo apt-get update
For i386 Users install Codecs using the following command
sudo apt-get install w32codecs libdvdcss2
For amd64 Users install Codecs using the following command
sudo apt-get install w64codecs libdvdcss2
Using above download locations you can install most of the mutimedia codecs for ubuntu.
Mplayer Plugin for Firefox
If you want to install Mplayer with plug-in for Mozilla Firefox run the following command
sudo apt-get install mozilla-mplayer
Posted on Apr 21, 2009
The sub woofer had a distorted sound.
the distorted sound coming out of your sub-w is actually originating from your audio unit, Have your audio unit check for possible repair
Oct 31, 2015 | Audio Players & Recorders
Fix distorted sound
Speaker hitting anything in the truck like seats or floor if they fire down? Enclosure in the way or not secure?
Jan 25, 2014 | Kicker Car Audio & Video
How do i fix the distorted sound i am getting?
If you are talking about some speakers of almost any type the paper in them gets old and brittle and they can even come apart--paper and cone separate from the frame of the speaker.
Usually if you can get at them to look you will be able to see if this has happened.
If this is not a speaker issue let me know what equipment you have etc.
SD TECH
May 24, 2012 | Televison & Video
How do I get rid of the distorted sound?
Hi
Could be your phones speaker.How old's the device?You may need to replace the speaker for clearer sound outputs.Also check the settings on this applications and make sure they're standard.
Feb 27, 2012 | Samsung Cell Phones
Iam using ubuntu 9.04.sound card is not working.I
If you are getting sound through your speakers then the sound system is working. If you lose the sound when using the headphone jack then either the headphone jack is faulty or your headphones are...
Although, rarely, you may find that opening the alsamixer from the terminal will fix the problem as some versions of Ubuntu have a special volume control for the headphone jack....
You will need to open the mixer as the Administrator
Type
su aslamixer
If this helped please vote kindly
Oct 07, 2009 | Canonical Ltd. Ubuntu
Hello,i have some problems with my dell laptop studio 1737 with ubuntu 8.10 and xp, the first one is with the sound card, it doesn't work correctly in ubuntu ; when i put the headphones in, the laptop...
Apparently this bug has been fixed already, you can apply patch if you're advanced user or just simply update to newer Ubuntu (e.g. new 9.04, out yesterday). More info here:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/309512
Mar 13, 2009 | Dell Studio 1737 Laptop
Ubuntu Sound Problem
MerryAnn, it sounds like any time your CPU does heavy work, you hear sounds..kinda like a buzzing? I would say off hand you have an open input turned up in the mixer.
Rredbare, do you dual boot? and what audio chip or model do you have?
Aug 25, 2008 | Canonical Ltd. Ubuntu
JBL PSW D112 Distorted Sound
your memory is low on resources need to increase memory.everything on ur pc uses mem.audio and video devices use an aweful lot.if you have open another program not only will ur audio be distorted but ur other program will be running slow.
correct? need to add more ram.
Mar 07, 2008 | HP Pavilion dv4000 Notebook
Distorted sound
Sounds like you have a bad speaker or where the mounts for the speaker are broke.
Dec 03, 2007 | Televison & Video
Poor sound/very low sound controls having no effect
That sounds like the main amp is failing. I suspect the unit will have one IC as the power amp, which will need replacing. You can have a look inside to see if you can see something like this:
power ic-ukkvwzzuppijvxoxp10or3yb-2-0.jpg If you do. Make a note of the number on it, it might say something like STK563. Then put your number into Google and it will give you a clue to how much it will cost and if it is obtainable. You can then either fix it yourself if you have the skills or take it to the repair shop.
May 31, 2017 | Aiwa AV-D58 Receiver
Canonical Ltd. Ubuntu Logo
352 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
k24674
Bill Boyd
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
