Question about Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel model degx1 wont heat after heating element upgrade
Dryer was heating ok but was having to reset the thermal protection about bi-weekly, so I installed the heating element upgrade kit "395711" in my 4 year old dryer following all instructions included with the kit. Turned the dryer on and now it wont heat at all. I noticed there was an extra set of contacts on the circuit board that came with the kit. My dryer is not wired for them. All ducts are clean and not restricted, all electrical connections are clean and solid. Moisture sensor in the drum is clean. This model does not have a display screen for trouble codes. Any ideas?? Also there was mention of a Tech Bulletin "S-FDRT-06-02". Anyone have a copy of this available?
  • Tom Andree Apr 21, 2009
    All parts that came with the kit were installed as instructed, all connections to both the external control panel and the circuit board are complete and secure, there is 220v at the dryer, the dryer runs through the cycles properly just with no heat.
  • 10,515 Answers
Hi Twandree,
I am offering you a link for service manual for your model. Do not distribute it on internet. Usually that might cost you many bucks to purchase that, However, taking the situation that you are at this moment attaching you a link to download :-
http://rapidshare.com/files/192052868/F_P_dryer.pdf
All youe service issues and tech information would be there.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 21, 2009
  • 15,935 Answers
395711 Heater Upgrade Kit Heater kit 395711 includes several additional parts that must be installed along with the heaters. Kit comes with all thermostats and a new sensor board. Be sure to replace ALL PARTS in this kit, even if the old parts appear to be good. Dryer performance will increase greatly with this kit. Check the connectors coming from the touch board to the sensor module (located on the left side, under the top deck) Look in the back left corner where the blue wires are tucked into a retainer clip and then the end is plugged into the sensor board. Make sure the connection is secure and check if you may have pinched or cut any of the wires in the process of working on the dryer. Look closely for a harness you may have missed. IF you are still having problems - or require proprietary help - please post on their forum HERE. Their techs will have the answer to your board problem. Thanks for using FixYa!!
Do I replace the heating element on my DEGX1 smartload dryer. Dryer is not heating. I have replace all of the venting inside and out. and cleaned all of the lint from the inside of dryer. Sometimes when...
I would guess thermal fuse:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
here is another good website:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Good Luck Tim
Mar 11, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not getting hot
Hello there:
f your dryer doesn't heat, check these: Heating element Thermal fuse Wiring f you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) c5f4c5f.jpg
Feb 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heatin element broken on my fisher & paykel dryer model # DEGX1
Try doing a Google search on the internet...put in your model number and make...look for parts
Sep 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
WHERE TO BY DUAL HEATING ELEMENT FOR DEGX1?
try sears .com..use parts link type in model #
Sep 07, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryer is not heating well
run for one cycle with the hose disconnected from wall. if it dreis faster then you have a restriction in the wall or ta the screen or flapper outside
Feb 17, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
363 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
