Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
I cant adjust my picture size to normal on my Sony Wega 51" TV
When I try to change screen size to normal the option is blacked out
    Novelist:
  • 159 Answers
The screen size feature is gray out because there is a previous option selected already and computer assumes you want always that size.So going into the menu and try to look for a previous selection related with: "screen size default". The menu allows you to selec this option and (i like to "standard" and i adjust screen size with my cable box feature who allows change size also if is needed, but now days cable box change it itself because is automatic) is install in the original program by manufacture because helps you to keep one size and you don't have to change it any moment. This default option is outside the regular screen size option, if i remember right is in set up screen. try to find this options in your user's manual to follow the right screen procedure..
Posted on Apr 25, 2009
Sony 34" XBR TV Picture does not fit on Screen. How to change setting?
Have you tried going to menu then to video options, screen size should be in that menu, also have got a zoom funtion on the remote, if so try using that. Do you have the owners manual, if not I will try to find a copy in PDF file format, just let me know.
Oct 13, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
How do I change the picture size?
You can change the picture size by using either the TV remote or the cable box remote (which ever you are using). Just go into the TV settings option, scroll through the different options that adjust everything from color and tint, sound, contrast, etc, and you should find one for changing the screen size (my Sony TV can be changed from normal, and wide, to wide zoom).
Sep 19, 2014 | Celcus LED40S0913FHD 40" LCD TV 1920x1080,...
The picture on my sony bravia 52 in is huge and I cant seem to be able to fix it. On the picture size it is set at wide mode and normal is not highlighted to be able to change it
Try pressing HOME, Then go to SETTINGS From the list, select SCREEN
There are now several options that may be causing the picture to zoom. Try adjusting each setting in the following order, checking if the problem has solved after each change.
Set: DISPLAY AREA to NORMAL WIDE MODE to NORMAL AUTO WIDE to OFF 4:3 DEFAULT to NORMAL
If you are still having problems, you may need to speak to Sony about having the TV serviced as an internal circuit may be broken - if this is the case it may be covered by the warranty.
I hope this helps - if you require more info, here is a link to the Manual for your tv http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/0451c422be8f7211d50375af6ace50aef8fb6504.pdf
May 04, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
TV is stuck in expanded picture mode & won't return to normal
seems to me as a Sony TV. The sony tv has this feature ready in the menu. you can do zoom out ,standard etc,
But the real problem comes when the tv is turn off and then you get back to turn on the tv (lets say next day)and you find the same big heads.
what you have to do is going to the menu same thing but this time look for an option is called picture size default. This option make learn the memory what size you want custom when tv is turn on.This function is in the same page as the picture size page (refer to the user's manual) but has to be the default mode where you want the change.
The problem with sizes now days is some shows fit perfect some others not. and besides that the cable box has those features too(change size of the screen)
What i do in this sony tv to start first is keeping it in the standard size in the tv menu and i defaulted too.
when some size adjustment is needed i do it in the cable box remote control .Once again this example i do it in SONY tv, Maybe you have to post the problem again if the tv is different brand.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
NORMAL OPTION GONE
the cable remote has a zoom feature in the settings. the zoom setting got turned on somehow. This feature overrides the picture size settings on the tv.
so, not a tv problem at all, but easily missed.
Dec 29, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Size of the picture decreased
If this only happens with your cable or satellite box this may be an adjustment in your box. So you may need to contact them and find out how to adjust the picture size. This tv may have a wide mode setting on the tv remote. Pushing this button may select full,wide,wide zoom or normal size. On many occasions the tv stations control the picture size. Good Luck
Jan 23, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
786 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
