SOURCE: My Garmin Colorado 300 is freezen
Better to update the colorado firmware to fix the certain problem on your unit.
Updates & Downloads
Colorado 300 software version 2.90
Download (3.46 MB)
Installation Instructions
Hope this initial info/idea helps.
Thank you for using fixya
SOURCE: how do i reset my
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:\Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
> cd c:\Garmin
At the next command prompt type the following command without hitting enter:
> Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
SOURCE: my garmin nuvi 205 wont go past the turn on
Maybe this will help you, I am giving you the link to the whole manual in detail that you can download in PDF.... This will tell you everything about your unit and trouble shooting and company contact numbers. I hope this helps if so, please rate my free help and some kind words would be nice in the comment section. Respectfully, Mike
Here is the Link>> http://www8.garmin.com/manuals/2675_OwnersManual.pdfb>
SOURCE: Garmin Colorado 300 not turn on
Put a fresh set of batteries in it.
Connect it to a computer and run the Garmin WebUpdater program to load or reload the latest software.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
