Question about Pure Digital Flip Video Ultra Camcorder
When finished downloading, we remove camcorder from Mac computer and receive a screen which says we must restart computer, that something incorrect has occurred. what do we have to do not to receive that message and upset the computer? loren
  • 4,889 Answers
You must safely remove hardware before disconnecting the device from your MAC. Find the device on your desktop, click on it and press CMD+E or press eject button on you keyboard. Then it will be safe to disconnect the camcorder.
Posted on Apr 21, 2009
My apple laptops login screen keeps going on and off on and off i cant login
Try resetting the SMC
Before Resetting the SMC Try each of the following steps in this order before you reset the SMC. Test the issue after completing each troubleshooting step to determine if the issue still occurs.
  1. Press Command + Option + Escape to force quit any application that is not responding.
  2. Put your Mac to sleep by choosing the Apple () menu from the upper-left menu bar and then choosing Sleep. Wake the computer after it has gone to sleep.
  3. Restart your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Restart.
  4. Shut down your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Shut Down.
If your Mac appears to be running normally but isn't responding, force the computer to shut down by pressing and holding the power button for 10 seconds. Note: You will lose any unsaved work in any open applications.
For Mac portables experiencing issues related to the MagSafe power adapter and/or battery, try:
  1. Unplug the MagSafe power adapter from the Mac and the wall power socket for several seconds.
  2. Shutdown the Mac. Physically remove and re-insert the battery (if it's removable) and startup the Mac.
If the issue is still not resolved after following the troubleshooting items above, an SMC reset may be necessary.
After performing normal troubleshooting, these symptoms may indicate that an SMC reset may be necessary:
Fans
The computer's fans run at high speed although the computer is not experiencing heavy usage and is properly ventilated.
Lights
The keyboard backlight appears to behave incorrectly (on Mac computers that have this feature).
The Status Indicator Light (SIL) appears to behave incorrectly (on Mac computers that have an SIL).
Battery indicator lights, if present, appear to behave incorrectly (on portables that use non-removable batteries).
The display backlight doesn't respond correctly to ambient light changes on Mac computers that have this feature.
Power
The computer doesn't respond to the power button when pressed.
A portable Mac doesn't appear to respond properly when you close or open the lid.
The computer sleeps or shuts down unexpectedly.
The battery does not appear to be charging properly.
The MagSafe power adaptor LED doesn't appear to indicate the correct activity.
System Performance
The computer is running unusually slowly although it is not experiencing abnormally high CPU utilization.
Application icons may "bounce" in the Dock for an extended amount of time when launched.
Applications may not function correctly or may stop responding after being opened.
Video
A computer that supports target display mode does not switch into or out of target display mode as expected.
A computer that supports target display mode switches into or out of target display mode at unexpected times.
Oct 20, 2013 | Computers & Internet
I need to reset a dell dimension 8400 to factory setting what f key do I use
Welcome to FixYa!
Using Dell PC Restore by Symantec
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC
Restore restores your hard drive to the operating state it was in when you purchased the computer.
Any programs or files added since you received your computer-including data files-are
permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail
messages, digital photos, music files, and so on. If possible, back up all data before using PC
Restore.
NOTICE: Using PC Restore permanently deletes all data on the hard drive and removes any applications
or drivers installed after you received your computer. If possible, back up the data before using PC
Restore.
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish restarting, and then
restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the
screens that appear, such as the End User License Agreement, are the same ones that
appeared the first time the computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Good Luck
Nov 11, 2010 | Dell Dimension 8400 PC Desktop
IMovie 09 / Mac OS X will not recognise Sony DCR-HC35 via firewire or USB? Do I need to download the correct driver?
mac doesn't support usb streaming so that leaves us with firewire. it should be a plug-and-play connection. no need to install any kind of driver for the camcorder (but try to check if there are any available driver updates for the firewire card).if possible try to check if your computer firewire port is working by using other devices.your imovie software should detect the camcorder once connected.if not, disconnect cam, open imovie, and connect again.if still doesnt,RESET camcorder.if still the same try restarting computer with cam connected and powered on.check if you have a dv in indicator on your screen.check if firewire cable connection is secured.try diff ilink cable if available.if still no go, try a diff computer. if everything fails might also be a service issue.hope this helps.tnx:)
Apr 16, 2010 | Sony DCR-HC35E Mini DV Digital Camcorder
I have a Dell c521 and I am trying to restore to factory settings but when I go into the the advanced boot options menu I don't have a repair mode like it is supposed to. It has other options that say to...
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC Restore restores your hard drive to the operating state it was in when you purchased the computer. Any programs or files added since you received your computer—including data files—are permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail messages, digital photos, music files, and so on. If possible, back up all data before using PC Restore.
Note: Using PC Restore permanently deletes all data on the hard drive and removes any applications or drivers installed after you received your computer. If possible, back up the data before using PC Restore.
To use PC Restore: 1 Turn on the computer and watch the keyboard status lights.
2 Immediately upon seeing the lights flash, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish restarting, and then restart the computer again.
Note: If you do not want to proceed with PC Restore, click Reboot in the following step.
The restore process takes approximately 6–10 minutes to complete.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
7 Click Next.
Cheers!
Mar 30, 2010 | Dell Dimension C521 PC Desktop
When i turn it on it's saying there's no such file directory. It's a dual core processor I tried to switch it from Os9 to Os10 and now it's got a black screen with this on it
Try starting from CD and check hard drive. Sounds like you installed something that may have corrupted something on your hard drive.
Jul 08, 2009 | Apple iMac G4 Desktop
Apple help
If you entered a password hint when you created the user account on your computer, then you can view the hint after entering an incorrect password. If not, and you have your original Apple restore disks, then you can reset your password by starting up from the cd. Put the CD into the drive and restart the computer by holding down the C key on your keyboard. When the computer restarts, click the Installer menu item at the top of the screen, then click Reset Password. Set the new password , then restart and voila, you're done.
Jul 05, 2009 | Apple iBook Mac Notebook
Chronos Soho Notes - Database
Hey I found the solution.
Reinstall Soho Notes but on the screen after accepting the license is a button marked cutstomize. Click on that and then make sure the database box is checked. Finish the installation and restart your machine. It worked for me
Mar 25, 2009 | Computers & Internet
After downloading Firm software update and shut down, comp gives whirring sound and didnt reboot - no picture on screen.
Place the system restore cd in the drive and restart. Hold down the C key til you see can tell it it restarting from the Cd. Once the screen to restore comes up, press the esc key... go to the top of the screen see the menus... choose the first aid utility. run an first aid diagnostic. choose repair if diagnostic finds issues... After you finish with the repair. quit and restart. Hold down the eject key while restarting. Remove restore CD.
let computer continue to restart. See if it gets beyond the whiring sound and if it boots up correctly.
Let me know if this does not work.
enov8
Mar 09, 2009 | Apple Customized 13 MacBook Notebook...
Pure Digital Flip Video Ultra Camcorder Logo
64 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
Ron Dufek
Ron Dufek
sharky633
sharky633
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
