Question about Maytag Neptune MDG5500AW Gas Dryer
Clothes dryer not producing heat
My clothes dryer is not producing heat. how do i know if it is the heat element or the high limit fuse.
  • granitegroup May 11, 2010
    what is the most likely problem for no heat?
  • 221 Answers
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Posted on Apr 25, 2009
How do I find the fuse and the heating element?
In a clothes dryer, there isn't a fuse as such. Any problems will knock out the breaker due the high amperage in the elements, and often 220 volt supply.
The elements do break over time. the are also covered by two safety devices, a high limit cut out and a high limit thermostat. If the high limit cut out fails, it needs replacing, and you also need to find the reason why, which is normally reduced airflow.
Google
make model spare parts
Google
Jul 29, 2017 | Dryers
LG TROMM DLE 3733W dryer Sometimes it won't heat and try the clothes and sometimes it will. I hear the high temp switch kick off when it doesn't work.
You might have excessive lint build up in the air flow inlet. Then excessive heat trips the thermostat limit switch. The thermostat limit switch could be defective too.
Oct 19, 2015 | Dryers
My Samsung DV5451AEW/XAA will not dry cloths. The vent tube is not plugged and air flow is great through the whole vent system. How do I get to the heating element?
  • I am assuming this is electric. Yes?
  • Do you get any heat when there is no clothes in it?
  • Have you checked your voltage at the receptacle? If not 220V, if you have the old tube fuses, then one may be blown. If you are getting good heat with no clothes then replace your high limit thermostat. Lots to check before heading for the heating element. As for heating element they are usually either in the back of the tub or a tube on the right hand side of the dryer. You need to take the front panel off.
Aug 03, 2013 | Samsung White Dryer Dv5451aew/xaa
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
Dryer will not produce heat to dry clothes
you first need to access the heating element case and with a multi-meter check the element for 50-250 ohms,then the hi-limit switch and cycling switch on this case,then on the dryer exhaust vent housing theres a thermal-fuse,check this for continuity all components will check 0 or near 0 ohms=good/infinity,no reading=bad/except the element and the above is just an approximation as each element has its own resistance
Mar 19, 2010 | Kenmore 800 6983 Electric Dryer
Does not produce heat to dry clothes
The ehating element is relatively easy to replace. You should be able to find a scematic wiring diagram in the owners manual. If you dont have one check on line they may have one on thier web page. While you are doing this go ahaed and check your master thermal fuse. It will be depicted onm the diagram to. The fuse is usually the cause.
Apr 27, 2009 | Dryers
Blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
Apr 15, 2009 | Dryers
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Oct 24, 2007 | Crosley CDE6000 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
448 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
