Question about Garmin Nuvi 350 Car GPS Receiver
SW Version Saying 0.00
I have the Garmin Nuvi 350 that I have had for about a year now. A few months back, for no particular reason, the SW Version on my GPS stated that it was 0.00 instead of the 3.00 version that came with it. Now it will not acquire satellites and at start up will say updating software but go directly to the main menu with nothing getting done.
I have gone to the Garmin website and ran a web update on it for the new 6.00 version but it will not install on there when I hook up the USB to it. The installation will say everything has been installed but the "about" section on the GPS says that it is still 6.00 on the SW Version. Does anyone have any suggestions what I might be doing wrong, or if there is another way of fixing this? Thank you all very much!
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Sorry to disagree ghana but your suggested solution makes no sense..... GPS S/W = 0.0 means there is a problem with the flip-up GPS receiver assembly. I've repaired many Nuvi's with this problem. It has nothing to do with the map. The Nuvi tries to update the GPS software each time at turn on but can't because it can't communicate with the GPS receiver and reupload the firmware into the GPS receiver. Only changing out the GPS receiver assembly or troubleshooting to the component level will resolve this issue.
    - Jim
    SHARCNET-USA
    www.sharcnet-usa.com
  • SHARCNET-USA
    Firmware version 6.0 relates to the operating system, that gives you your menus on the screen. The GPS S/W is the firmware in the GPS RF receiver (SIRF receiver).
    The latest OS firmware is 6.0. The latest GPS S/W is 3.0.
    If the GPS S/W is saying 0.0 and trying to do an update at turn-on, it is because there is a failure on the flip-up antenna GPS receiver board and the board needs to be replaced. Please see this link on how to get your unit repaired.
    http://www.sharc.net/gps_antenna_repair....
    - Jim
  • 121 Answers
That's because of the map you have to updata the map and you have to download the quick gps fix
Posted on May 04, 2009
  • 504 Answers
SOURCE: Garmin Nuvi 350 GPS is off
If the GPS is off, you have to go into the settings menu and change it. There should be three settings - Normal, GPS off and WAAS/EGNOS. Choose Normal or WAAS/EGNOS and you should be ok.
Posted on Jan 28, 2008
SOURCE: Garmin Gps Nuvi 300/350 stopped
I got a solution for this issue - buy a SPI Mini-Hi-Fi speaker - it's to be connected directly to the GPS output, there is no cord or cable, it's very light, sounds pretty well and it's totally affordable (around $10).
I've been used it for weeks, no problem at all!!!!!!!!!!!
Posted on May 20, 2009
  • 4090 Answers
SOURCE: my garmin nuvi gps is not working, says acquiring
Hello.
Some of the problems that cause this are as follows
Battery power is too low recharge or replace the battery
The BAUD rate and PORT are not set correctly.
consult the manual for the right parameters, or use the autoconnect option in the settings GPS where it shows the satellites
The SIIRF chip is damaged ( you hope not!) as this is an expensive repair
Posted on Jul 29, 2009
SOURCE: Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Posted on Nov 19, 2009
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
GPS - Garmin Nuvi 350 has mind of its own
Reset behind Antenna, press this in
and update it at Garmin
Should be good.
Regards
Ric.
May 16, 2009 | Garmin nuvi 350 GPS Receiver
I need to update maps on nuvi 350
Download new maps from eMule. Problem solved ;-)
Dec 18, 2008 | Garmin nuvi 350 GPS Receiver
Garmins Nuvi 350 - voice interactive lost
I have the same problem with my Nuvi 350. It's only about 2 months old and the sound went. I turned it on the other day to use it and the sound did not sound right, it sounded like the speaker was blown. I turned it off and turned it back on and that was it, the sound was gone. I did everything possible and can't get the sound to come back. I called Garmin and now I have to send it in for repair. I looked around the web and noticed that Garmins have big issues with the sound going on the units. I hope they fix that issue.
Jul 28, 2008 | Garmin nuvi 350 GPS Receiver
N?vi 350
mumbo jumbo....use the webupdater, check the firmware and voice/text you need, the web updater will download them to the nuvi, when downloaded webupdater will tell you, unplug the nuvi and wait patiently for it to reboot about twice....finished.
Jun 19, 2008 | Garmin nuvi 350 GPS Receiver
Satellite reception
I have being having similar problem as every one else. There is nothing wrong with your Nuvi. Garmin (the company is the problem) they are trying to make you buy a new map--Not Exactly Cheap--Do Hard Reset and solve all the problems.
1) Place a finger (Any finger, middle finger worked for me!) at the left lower corner and turn on the Nuvi unit a message appear saying "Do you really want to start up in maintenance mode?" tap Yes
2) At the Maintenace screen tap clear user data (this will restore to factory condition) and follow the instruction on adjusting your prefered setings.
3) turn it off and Repeat step 1, this time when you get to maintance screen tap on "Clear waypoints" and follow the instruction. Let it sit for about an hour then voila.
Nov 05, 2007 | Garmin nuvi 350 GPS Receiver
Blank screen
I had the same problem, so I hit the side of the Garmin a few times. It works perfectly now. Something inside was unaligned and needed a little force to knock it into place. I didn't hit it HARD.
Sep 09, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
897 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
