Door knob I have a door knob on a room that is loose and I can't figure out how to tighten it. There are no screws on either knob plate, so I can't seem to get it off. I do see in the 1/4 -1/2 inch gap that there are some screws inside the knob. What a puzzle. I have tried just turning it clockwise and counterclockwise and that seems to tighten it but it doesn't stay tight. ANy clues?
  • 2 more comments
  • jbjb Sep 25, 2007
    No cap or grub screw on this door knob. Just a solid white knob on a gold colored ring, which moves separately. On both sides of the door the knob and ring are about 1/4 to 1/2 inch away and I can see some screws inside but don't know how to get in there...
  • jbjb Sep 25, 2007
  • jbjb Sep 25, 2007
  • jbjb Sep 25, 2007
Go buy a normal one *******
Posted on Jun 14, 2008
    Novelist:
    Scholar:
  • 117 Answers
A couple of ideas: Sometimes the top of the knob is a cap which can be levered off with a sharp blade. Or, there is a grub screw (which may need a hex key to turn it) in a hole on the underside of the knob.
Posted on Sep 22, 2007
SOURCE:
Weiser door knob GA9771A-S. Loose interior door knob. How do I tighten?
Remove the knob by pushing in the small pin on the edge of the knob shaft. Then use a screwdriver in the small inset on the edge of the handle cover to pop the cover off. Tighten the 2 screws under the cover, replace parts.
Mar 25, 2014 | Hardware & Accessories
Outside handle is loose on Schlage entry lock
Remove the inner handle and cover plate, tighten the 2 screws under the plate. Re-assemble.
Dec 21, 2013 | Schlage Hardware & Accessories
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Can't remove the disk that covers the screws to tighten door handle with lock
Hi, W/D here.
Kwikset has basically two styles of cover plates.
If you are on the locking side of the door and facing the knob you'll either see two screw heads (one on either side of the knob), or you see only the cover plate.
It sounds like you have the cover plate type. Here's how to get to the screws:
1. Feel the underside of the knob, and you'll feel a slot with a tab sticking through it.
2. With a fine bladed screwdriver, press the tab up into the slot, and pull the knob towards you.
3. With the door knob off, look around the edge of the trim ring for a screw driver slot. Insert the screw driver and gently pry the trim ring up.
4. You're there!
5. Re-assembly is in the reverse order. When you go to put the knob back on, you'll probably have to use the screw driver to push in the tab as you slide the knob back on.
Best regards, --W/D--
Jan 30, 2011 | Kwikset Professional Door Lock...
How do I remove the doorknob from a weiser passage set? Want to paint door and remove passage set. Can't seem to find any slot to remove doorknob.
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Nov 03, 2009 | Hardware & Accessories
My knob has fallen off
sounds like the lockset has come apart in a way that it was not intended... normally you need to push a small spring loaded pin on the knob shaft in to remobe the knob, then a finished trim plate snaps off revealing the plate that gets tightened down to the face of the door... after tightening you snap the trim plate back on then the knob snaps on while pushing the pin in...
if it's a standard bedroom unkeyed lock then the plate and knob are one piece and the screws are exposed thru 2 holes on the inside knob...
Sep 02, 2009 | Kwikset Professional Door Lock...
Door lock is loose
Inside plate arond the base of the knob needs to pop off.
Try removing the knob from the inside. Look for a place the push in with a flat head screwdriver. A release point is there some where.
After the knob is off the plate should come off and reveal the screws.
Mar 30, 2009 | Kwikset Professional Door Lock...
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
Open Questions:
Computers & Internet Logo
243 people viewed this question
Ekse
Alun Cox
